Just got my 270s and was wondering if I need to completely disassemble and check all valve/guide clearances, spring pressures and so on. Can I just check spring pressures on one or two valves on each head?
I will obviously be checking piston to valve, push rod and other clearances as well as rocker arm geometry.
Tell me from experience with Trick Flow heads how yours turned out.
