Edelbrock Victor heads #2542164
08/27/18 09:15 PM
08/27/18 09:15 PM
Kentucky
71blackdemon Offline OP
Kentucky
Has anybody ran the Edelbrock Victor small block Chrysler heads and how do they compare to the W5 heads I'm running W5 on my 416 in 3: 40 the car weighs 3400 lb with me in it and it runs 6: 39 at 107 miles per hour in the eighth how do you think the Edelbrock Victor's will do on this engine
Re: Edelbrock Victor heads [Re: 71blackdemon] #2542165
08/27/18 09:16 PM
08/27/18 09:16 PM
Kentucky
Kentucky
the only reason I'm thinking about changing is my W5 leak a little bit of water in one cylinder every once in awhile if I could seal them up I would stay with them any suggestions
Re: Edelbrock Victor heads [Re: 71blackdemon] #2542168
08/27/18 09:18 PM
08/27/18 09:18 PM
Carson City, Nevada
Biginchmopar Offline
Carson City, Nevada
I know Brett Miller was working on a couple deals with Victors, maybe he'll chime in.
Re: Edelbrock Victor heads [Re: 71blackdemon] #2542173
08/27/18 09:25 PM
08/27/18 09:25 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
. I think the Victor would be worth quite a bit of horsepower over the W 5s in the right hands.. like all heads they have some things you would change but they definitely can move a ton of air... I have seen Flow numbers in the 390 range.. on a set of Victors that Brett Miller did and we're flowed at QMP in California
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: Edelbrock Victor heads [Re: 71blackdemon] #2542229
08/27/18 11:12 PM
08/27/18 11:12 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
I’ve been watching with interest since the intro of these heads into the catalog back in 12. Our W5 mill expired from water injection into the #3 cyl (2nd time). We were going to center our build around our second set of W5’s, but after the “didn’t you learn anything the first time” conversation with our builder, we sold everything W5 and patiently waited for a head that never appeared. I was actually surprised that we completed our W8 build and still no Victors back in 14.
Brett is nearing the end of a build (Victor on Ritter block) that had been completed and ran, but don’t know the details on what happened, but it ended up in his hands. That was the only engine that I’ve heard of that ran with these heads.
I understand that many of these heads go to Aussi... maybe some of those members can chime in.
Like everything Mopar related.... bad timing. If we have blocks, we don’t have heads. If we have heads, we don’t have blocks.
Re: Edelbrock Victor heads [Re: 71blackdemon] #2542234
08/27/18 11:16 PM
08/27/18 11:16 PM
Kentucky
Kentucky
The Victor had supposedly flow 3: 35 at 700 right out of the box that's what my W5 flow with a lot of work
Re: Edelbrock Victor heads [Re: J_BODY] #2542238
08/27/18 11:22 PM
08/27/18 11:22 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
There are couple guys who have posted on here running Victors. One guy i think goes by Lawndart, the other guy has like a 68 cuda he runs on a stop with them if i remember right.
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Edelbrock Victor heads [Re: 71blackdemon] #2542241
08/27/18 11:27 PM
08/27/18 11:27 PM
Kentucky
Kentucky
does anyone have any ideas what I can put in my radiator to seal up the horse W5 heads I used to run just some regular sealer in it and it worked fine for a couple of years now it has started leaking in the number 5 cylinder after it sets a couple days
Re: Edelbrock Victor heads [Re: 71blackdemon] #2542242
08/27/18 11:32 PM
08/27/18 11:32 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
I used to run W5’s myself.
About the stoutest i have seen them run( and i am sure there are better) is right at 140 mph at 3320 ish. That on super stock springs. I know it made 708 when dyno’ed at Best Machine. The ET agrees with that. Thats my old car and motor, but the motor was upgraded, cam/squeeze/ gas porting, etc. from when i had it. I think J went 138 with his
I would think the Victors have the potential to make 150 more horse than that, perhaps more. Just a guess.
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Edelbrock Victor heads [Re: 71blackdemon] #2542243
08/27/18 11:33 PM
08/27/18 11:33 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Call Ryan at Shady Dell speed shop
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Edelbrock Victor heads [Re: 71blackdemon] #2542277
08/28/18 12:49 AM
08/28/18 12:49 AM
New Smyrna Beach FL
scottb Offline
scottb  Offline
New Smyrna Beach FL
Call titan sealer Best sealer out there
Re: Edelbrock Victor heads [Re: 71blackdemon] #2542292
08/28/18 01:25 AM
08/28/18 01:25 AM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Waterglass (sodium silicate) works on cracked cast iron heads and blocks. Can't see why it wouldn't work on aluminum. You have to be careful with how much you use as it will plug a rad up solid. It has that glass nickname for a reason.
https://en.m.wikipedia.org/wiki/Sodium_silicate
Kevin
Re: Edelbrock Victor heads [Re: 71blackdemon] #2542300
08/28/18 01:57 AM
08/28/18 01:57 AM
Washington
skrews Offline
skrews  Offline
Washington
GM seal tabs. Work very well.
https://www.ebay.com/p/Genuine-GM-123782...4970&chn=ps
Re: Edelbrock Victor heads [Re: B3422W5] #2542317
08/28/18 03:10 AM
08/28/18 03:10 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Unless his plan of attack has changed, he would epoxy it. In our case it came out, and locked the motor up on the return road 150 passes later. Took only 50 passes to figure out the original port work found a thin spot so we tore it down and sent the head back. I could write a novel on this painful experience, but here’s what I’d do. I’d try any sort of sealer. I’d probably try the GM tablets, or the CRC block sealer. Next would be to remove the head and look into any sealer/epoxy that could be flowed into the cooling passages.
Btw back then the car wasn’t 9 legal so my dad shifted at 5500 and was running low 10s. On one pass they shifted at 7200 and ran a 9.84 iirc. I think at 136....
Jay
Re: Edelbrock Victor heads [Re: 71blackdemon] #2542380
08/28/18 11:19 AM
08/28/18 11:19 AM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
What else besides the heads, rockers, head studs, and likely pushrods.......are required to do the swap?
Pistons still okay?
Headers I think are supposed to fit.
Valve covers?
Intake manifold?
Re: Edelbrock Victor heads [Re: 71blackdemon] #2542384
08/28/18 11:26 AM
08/28/18 11:26 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
The thing I find odd about the Victors is that while they require special everything they use a standard LA intake.
I kept my Super Victor EFI manifold just in case the money fairy(lottery) allows me to replace my Ported W2s with Victors one day.
68 Barracuda Formula S 340
Re: Edelbrock Victor heads [Re: fast68plymouth] #2542409
08/28/18 12:04 PM
08/28/18 12:04 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Pistons still okay?
Valve covers?
Intake manifold?
New pistons are needed
It’s not a cheap
Upgrade
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Edelbrock Victor heads [Re: 71blackdemon] #2542450
08/28/18 01:01 PM
08/28/18 01:01 PM
sst404b Offline
sst404b  Offline
We ran a set of the CNC heads and a Super Victor intake with nothing more than clean up CNC marks on the heads and match the intake on a 440 inch Ritter block.We used the Hughes rockers at first.They work fine under .700 lift and are affordable and the assembled heads come with valves and springs good to .650. The bore on ours was 4.185 so a piston had to be made but dome was no different than W5.Valves are at a different angle so check piston to valve clearance.You will also need to replace push rods.Valve covers are standard LA and we drilled our W2 headers to fit and they worked.It is worth the effort to swap to the Victor heads IMO because they are available, they don't leak water and they make good power.Brett Miller has a program and has worked on our heads. We had an intake made along with other changes to see how far we can take this combo,which BTW should be on the pump this week.
Ray
Re: Edelbrock Victor heads [Re: fast68plymouth] #2542451
08/28/18 01:01 PM
08/28/18 01:01 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Pistons still okay?
Valve covers?
Intake manifold?
Requires different header. TTI now makes them.... pricy.... 1200 ish
Different valve angle..... custom piston?
Pricy rocker gear
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Edelbrock Victor heads [Re: B3422W5] #2542458
08/28/18 01:15 PM
08/28/18 01:15 PM
PA.
"Little"John
"Little"John
PA.
Most of the guys appear to be using these on bigger bore aftermarket blocks too so the larger valves and a .030 over 360 block may not play well together.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
