Re: Distributor question
[Re: mod381]
#2540725
08/24/18 03:08 AM
08/24/18 03:08 AM
RapidRobert
As said I think one of your parts houses has rebuilt ones for cheap (advance auto, exchange iirc) & hookup the can is a good plan (to ported if available) but many people say manifold is the way to go (takes a different approach) then spend some time dialing in the dist subsystems (in order) as there is alot of gain to be had.
[Re: mod381]
#2540893
08/24/18 02:23 PM
08/24/18 02:23 PM
Posts: 25,823 Rio Linda, CA
John_Kunkel
Rio Linda, CA
If the truck has Lean Burn, the distributor has two pickups inside.
[Re: mod381]
#2540921
08/24/18 03:54 PM
08/24/18 03:54 PM
Posts: 10,228 Colleyville
3hundred
Colleyville
I need to replace the distributor in a 87 pick-up with a 318. The distributor that is in it has no vacuum advance on it. It does have the vacuum line that goes to the control module on the fender to control the vacuum advance. My question is can I use a distributer with the vacuum advance on it and just leave the vacuum actuator capped off on the distributor or do I need to find a distributer with out it like the one thats in it? You need the right distributor. I suspect the first pic is what you already have. The second pic is what you could use to eliminate the computer system. Similar to this one at Summit linky. Robert
'68 Fury Convertible '69 300 Convertible '15 Durango 5.7 Hemi '16 300 S Hemi
[Re: mod381]
#2540950
08/24/18 04:51 PM
08/24/18 04:51 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
by 87 replacing lean burn is more complicated than just putting in another distributor. Carb needs replaced as well.
