hole saw
#2529048
07/30/18 02:38 PM
07/30/18 02:38 PM
Posts: 7,274 s.w.fl
bonefish
s.w.fl
is there a good quality hole saw that will cut a clean 1 in. to 2in. hole in 3/16 aluminum plate.all i have is a drill press,no fancy equp.THANKS.
Re: hole saw
[Re: bonefish]
#2529151
07/30/18 05:28 PM
07/30/18 05:28 PM
Posts: 4,274 Morrow, OH
markz528
Morrow, OH
Go slow with lubrication. Use aluminum compatible cutting fluid or kerosene for lubrication.
Re: hole saw
[Re: markz528]
#2529227
07/30/18 08:06 PM
07/30/18 08:06 PM
Posts: 350 Mequon, WI
gzig5
Mequon, WI
Go slow with lubrication. Use aluminum compatible cutting fluid or kerosene for lubrication. WD40 is an effective lubricant for aluminum. You are going to want the slowest possible speed the drill press can provide. Much more than a couple hundred rpm will likely be trouble. Clean out the chips often.
Re: hole saw
[Re: Just-a-dart]
#2529356
07/31/18 12:04 AM
07/31/18 12:04 AM
Posts: 52,972 Romeo MI
MR_P_BODY
If I have to have a nice round hole I use a little smaller hole saw then use my adjustable boring bar in the mill.. turns out perfect
Re: hole saw
[Re: bonefish]
#2529373
07/31/18 12:35 AM
07/31/18 12:35 AM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
Seems you need a simple cut, get a Bi Metal hole saw, home depot, lowes etc. You don't need anything fancy for what you are doing, I agree go slow and a little lubricant couldn't hurt, but not needed for a single cut like your asking about. NO high speed spins, and your fine.
Re: hole saw
[Re: bonefish]
#2529468
07/31/18 12:20 PM
07/31/18 12:20 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
Annular cutter in a ridgid fixture.
Re: hole saw
[Re: MR_P_BODY]
#2529663
07/31/18 06:36 PM
07/31/18 06:36 PM
Posts: 25,849 Rio Linda, CA
John_Kunkel
Rio Linda, CA
If I have to have a nice round hole I use a little smaller hole saw then use my adjustable boring bar in the mill.. turns out perfect Me too, never got a nice correct dimension hole with a hole saw.
