1968 Dodge truck #2515263
06/30/18 01:11 PM
06/30/18 01:11 PM
PA USA
BING Offline OP
BING  Offline OP
PA USA
where is the horn relay located on a 68 D 100?
Re: 1968 Dodge truck [Re: BING] #2515623
06/30/18 10:46 PM
06/30/18 10:46 PM
Welcome aboard (fasten your seat belt!). I have a 65 D100 & I can check tomorrow.
Re: 1968 Dodge truck [Re: BING] #2515771
07/01/18 11:19 AM
07/01/18 11:19 AM
Des Moines IA
Soopernaut Offline
Soopernaut  Offline
Des Moines IA
If it has a single horn there may not be a relay.
1970 Dodge d100/eventually going on a 77 D100 frame
Re: 1968 Dodge truck [Re: BING] #2515895
07/01/18 03:10 PM
07/01/18 03:10 PM
Engine compartment, firewall or mounted on the fender wells scope
Re: 1968 Dodge truck [Re: Cab_Burge] #2516082
07/01/18 10:15 PM
07/01/18 10:15 PM
I was surprised to not see a horn relay on the firewall. there is the 2 wire "L" connector/wire going up to the horn under the hood (no idea if this is OE or not) & there is something missing on the firewall just behind the cyl head (I thought it was the ballast but the ballast is there further to the drivers side). I think that that might be the voltage reg that is missing.
Re: 1968 Dodge truck [Re: Soopernaut] #2516100
07/01/18 10:34 PM
07/01/18 10:34 PM
PA USA
BING Offline OP
BING  Offline OP
PA USA
IT LOOKS LIKE IT JUST HAS ONE HORN. IT HAS A T CONNECTOR. I'M USED TO HORNS HAVING A SINGLE CONNECTOR. DOES ANYBODY HAVE A TWO CONNECTER HORN?
Re: 1968 Dodge truck [Re: BING] #2516119
07/01/18 10:53 PM
07/01/18 10:53 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Any local parts store will have one.
Re: 1968 Dodge truck [Re: BING] #2516493
07/02/18 05:30 PM
07/02/18 05:30 PM
Des Moines IA
Soopernaut Offline
Soopernaut  Offline
Des Moines IA
It's usually on the radiator support, if you have one.
