Re: 1968 Dodge truck
[Re: BING]
#2515623
06/30/18 10:46 PM
06/30/18 10:46 PM
RapidRobert
Welcome aboard (fasten your seat belt!). I have a 65 D100 & I can check tomorrow.
[Re: BING]
#2515771
07/01/18 11:19 AM
07/01/18 11:19 AM
Posts: 2,684 Des Moines IA
Soopernaut
Des Moines IA
If it has a single horn there may not be a relay.
1970 Dodge d100/eventually going on a 77 D100 frame
[Re: Cab_Burge]
#2516082
07/01/18 10:15 PM
07/01/18 10:15 PM
RapidRobert
I was surprised to not see a horn relay on the firewall. there is the 2 wire "L" connector/wire going up to the horn under the hood (no idea if this is OE or not) & there is something missing on the firewall just behind the cyl head (I thought it was the ballast but the ballast is there further to the drivers side). I think that that might be the voltage reg that is missing.
[Re: BING]
#2516493
07/02/18 05:30 PM
07/02/18 05:30 PM
Soopernaut
Des Moines IA
It's usually on the radiator support, if you have one.
