Re: Can you use mopar steel shim head gasket on aluminum head
[Re: drifter]
#2501498
05/28/18 10:26 PM
05/28/18 10:26 PM
Posts: 6,257 gulfport, ms, west mi
rowin4
I used them on my 505 stroker, No leaks. But union the freshen up I did notice the steel left a impression in the aluminum.
[Re: drifter]
#2501584
05/29/18 03:35 AM
05/29/18 03:35 AM
Posts: 5,162 CT
GTX MATT
CT
I used steel shim (Mr Gasket) with the Stealth heads to get .040 quench and have not had a problem
[Re: drifter]
#2501967
05/29/18 09:46 PM
05/29/18 09:46 PM
Posts: 4,848 Memphis
HemiRick
Memphis
My 451 has been running fine for 11 years w Edelbrock heads and mopar steel shims and copper coat.
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
[Re: drifter]
#2503053
06/01/18 09:22 AM
06/01/18 09:22 AM
Posts: 1,774 Keymar, MD
DusterKid
Keymar, MD
I've ran the Mr. Gasket P/N 1135 for 10 yrs (125-200 passes a yr depending on how well I did) with 440 source heads without an issue. Did freshen up the engine twice during that time. Was running just a tad over 10:1 compression. Never had an issue.
[Re: drifter]
#2503062
06/01/18 09:57 AM
06/01/18 09:57 AM
Posts: 11,713 Portage,michigan
B3422W5
Portage,michigan
Have 028 steel shim on my motor with eddies
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: drifter]
#2503325
06/01/18 08:28 PM
06/01/18 08:28 PM
Posts: 10,006 Frostbitefalls MN (Rocky&Bullw...
gregsdart
If i were to try it, i would use copper coat and do a retorque for sure. Someone reported marks left on the aluminum heads, so a rwtorque would be in need.
