Can you use mopar steel shim head gasket on aluminum head #2501409
05/28/18 06:57 PM
05/28/18 06:57 PM
this world
drifter Offline OP
drifter  Offline OP
this world
Has anyone used the mopar steel shim head gaskets on aluminum heads with good results?
Re: Can you use mopar steel shim head gasket on aluminum head [Re: drifter] #2501413
05/28/18 07:10 PM
05/28/18 07:10 PM
Kirkland, Washington
Pacnorthcuda Offline
I've heard of people doing it, also heard it's not a good idea.
I am using the .027 Cometics under my 440 source heads.
Re: Can you use mopar steel shim head gasket on aluminum head [Re: Pacnorthcuda] #2501457
05/28/18 09:04 PM
05/28/18 09:04 PM
this world
drifter Offline OP
drifter  Offline OP
this world
How have they been for leaks water or oil ?
Re: Can you use mopar steel shim head gasket on aluminum head [Re: drifter] #2501484
05/28/18 09:46 PM
05/28/18 09:46 PM
AndyF Offline
AndyF  Offline
The OEM guys invented the MLS gasket to fix problems they were having with blown head gaskets. Remember the Vega and other cars like that? That is why MLS gaskets exist.
Re: Can you use mopar steel shim head gasket on aluminum head [Re: drifter] #2501498
05/28/18 10:26 PM
05/28/18 10:26 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
I used them on my 505 stroker, No leaks. But union the freshen up I did notice the steel left a impression in the aluminum.
Re: Can you use mopar steel shim head gasket on aluminum head [Re: drifter] #2501520
05/28/18 11:27 PM
05/28/18 11:27 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Currently using them on a fiends 440 w/ Eddy heads. He bought open chamber heads used. We used them to get the compression up to 10.0-1. Together 2 years, no leaks. Solid 11.30 car.
Doug
Re: Can you use mopar steel shim head gasket on aluminum head [Re: drifter] #2501584
05/29/18 03:35 AM
05/29/18 03:35 AM
CT
GTX MATT Offline
GTX MATT  Offline
CT
I used steel shim (Mr Gasket) with the Stealth heads to get .040 quench and have not had a problem
Re: Can you use mopar steel shim head gasket on aluminum head [Re: GTX MATT] #2501761
05/29/18 02:52 PM
05/29/18 02:52 PM
dogdays Offline
dogdays  Offline
Judging from the last several years here, many have used the steel shims with aluminum heads. My warning would be that both surfaces need to be really flat.
R.
Re: Can you use mopar steel shim head gasket on aluminum head [Re: drifter] #2501967
05/29/18 09:46 PM
05/29/18 09:46 PM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
My 451 has been running fine for 11 years w Edelbrock heads and mopar steel shims and copper coat.
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: Can you use mopar steel shim head gasket on aluminum head [Re: Pacnorthcuda] #2502897
05/31/18 09:07 PM
05/31/18 09:07 PM
Montreal Quebec
STROKIE Offline
STROKIE  Offline
Montreal Quebec
iagree
Re: Can you use mopar steel shim head gasket on aluminum head [Re: drifter] #2503053
06/01/18 09:22 AM
06/01/18 09:22 AM
Keymar, MD
DusterKid Offline
DusterKid  Offline
Keymar, MD
I've ran the Mr. Gasket P/N 1135 for 10 yrs (125-200 passes a yr depending on how well I did) with 440 source heads without an issue. Did freshen up the engine twice during that time. Was running just a tad over 10:1 compression. Never had an issue.
Re: Can you use mopar steel shim head gasket on aluminum head [Re: drifter] #2503062
06/01/18 09:57 AM
06/01/18 09:57 AM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Have 028 steel shim on my motor with eddies
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Can you use mopar steel shim head gasket on aluminum head [Re: drifter] #2503325
06/01/18 08:28 PM
06/01/18 08:28 PM
gregsdart Offline
gregsdart  Offline
If i were to try it, i would use copper coat and do a retorque for sure. Someone reported marks left on the aluminum heads, so a rwtorque would be in need.
Re: Can you use mopar steel shim head gasket on aluminum head [Re: drifter] #2503341
06/01/18 09:32 PM
06/01/18 09:32 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
We used no copper coat and have not retorqued.
Doug
