Re: Can you use mopar steel shim head gasket on aluminum head
[Re: drifter]
#2501498
05/28/18 10:26 PM
05/28/18 10:26 PM
Posts: 6,257 gulfport, ms, west mi
rowin4
I used them on my 505 stroker, No leaks. But union the freshen up I did notice the steel left a impression in the aluminum.
[Re: drifter]
#2501584
05/29/18 03:35 AM
05/29/18 03:35 AM
Posts: 5,164 CT
GTX MATT
CT
I used steel shim (Mr Gasket) with the Stealth heads to get .040 quench and have not had a problem
[Re: drifter]
#2501967
05/29/18 09:46 PM
05/29/18 09:46 PM
Posts: 4,848 Memphis
HemiRick
Memphis
My 451 has been running fine for 11 years w Edelbrock heads and mopar steel shims and copper coat.
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
[Re: drifter]
#2503053
06/01/18 09:22 AM
06/01/18 09:22 AM
Posts: 1,775 Keymar, MD
DusterKid
Keymar, MD
I've ran the Mr. Gasket P/N 1135 for 10 yrs (125-200 passes a yr depending on how well I did) with 440 source heads without an issue. Did freshen up the engine twice during that time. Was running just a tad over 10:1 compression. Never had an issue.
[Re: drifter]
#2503062
06/01/18 09:57 AM
06/01/18 09:57 AM
Posts: 11,723 Portage,michigan
B3422W5
Portage,michigan
Have 028 steel shim on my motor with eddies
[Re: drifter]
#2503325
06/01/18 08:28 PM
06/01/18 08:28 PM
Posts: 10,011 Frostbitefalls MN (Rocky&Bullw...
gregsdart
If i were to try it, i would use copper coat and do a retorque for sure. Someone reported marks left on the aluminum heads, so a rwtorque would be in need.
