1969 340 Distributor cap #2494173
05/09/18 11:39 PM
05/09/18 11:39 PM
Warrenton, VA
RoadRunnerJD Offline OP
Warrenton, VA
What color was the OE distributor cap?
Re: 1969 340 Distributor cap [Re: RoadRunnerJD] #2494496
05/10/18 07:55 PM
05/10/18 07:55 PM
Lee Co. Fla.
5carguy Offline
5carguy  Offline
Lee Co. Fla.
Depends which distributor it is.Duel or single point
Re: 1969 340 Distributor cap [Re: RoadRunnerJD] #2494504
05/10/18 08:42 PM
05/10/18 08:42 PM
BlueRacer69 Offline
BlueRacer69  Offline
Should probably be Tan in color.
Re: 1969 340 Distributor cap [Re: RoadRunnerJD] #2494511
05/10/18 09:15 PM
05/10/18 09:15 PM
Warrenton, VA
Warrenton, VA
340 Dual point Prestolite. The reason I am asking is that it had a black cap on it when I bought the car years ago and I thought I read somewhere that it should be black on 1969 340 cars but now that I am getting it back together, I am having second thoughts that all the 69 Mopar muscle cars had tan ones? I know that all my 383/440/426 Hemi cars in the past had tan ones but I never had a 340 car before now.
Re: 1969 340 Distributor cap [Re: RoadRunnerJD] #2494561
05/10/18 11:15 PM
05/10/18 11:15 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
dist type makes no difference, Tan
Re: 1969 340 Distributor cap [Re: RoadRunnerJD] #2494580
05/11/18 12:04 AM
05/11/18 12:04 AM
Warrenton, VA
Warrenton, VA
Thanks Bill. Tan is what I put on it.
Re: 1969 340 Distributor cap [Re: RoadRunnerJD] #2494601
05/11/18 12:58 AM
05/11/18 12:58 AM
gretna, Ne
O
oem6pak Offline
oem6pak  Offline
O
gretna, Ne
What about the plug wires on the same engine? Black or I've also seen orange?
Pure Stock Rules
Re: 1969 340 Distributor cap [Re: oem6pak] #2494669
05/11/18 09:38 AM
05/11/18 09:38 AM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
Black until 1970 I believe. work
JB Rhinehart, Realist
A-Body's RULE!
Re: 1969 340 Distributor cap [Re: Rhinodart] #2494712
05/11/18 11:22 AM
05/11/18 11:22 AM
New York
rarefish Offline
rarefish  Offline
New York
Here is a pic of the factory installed dual point cap and wires on my 69 Dart 340 engine.
Re: 1969 340 Distributor cap [Re: oem6pak] #2494755
05/11/18 02:03 PM
05/11/18 02:03 PM
Warrenton, VA
Warrenton, VA
Never orange
Re: 1969 340 Distributor cap [Re: Rhinodart] #2494764
05/11/18 02:12 PM
05/11/18 02:12 PM
Warrenton, VA
Warrenton, VA
That’s what I thought I knew but I am going with tan for now? I’d like things as correct as possible but I’m really not going for OE platinum judging. scope
Re: 1969 340 Distributor cap [Re: RoadRunnerJD] #2494767
05/11/18 02:21 PM
05/11/18 02:21 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Tan caps showed up approx 1966 give or take a year or so depending on plant.
Black wires with yellow lettering up till approx very late 1971...mainly 1972 is standard
Re: 1969 340 Distributor cap [Re: rarefish] #2494954
05/11/18 11:45 PM
05/11/18 11:45 PM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
Very nice. Looks un-restored engine?
Re: 1969 340 Distributor cap [Re: kentj340] #2495140
05/12/18 03:13 PM
05/12/18 03:13 PM
New York
rarefish Offline
rarefish  Offline
New York
You are correct. It is un-restorded. All factory original except for the the fuel filter, fan belt and the two heater hoses.
