does the passon O/D 4 speed gearset require special 3-4 rod? #2489522
04/29/18 02:45 PM
04/29/18 02:45 PM
BC Canada
O
ogopogo Offline OP
ogopogo  Offline OP
O
BC Canada
I just installed a 66 4 speed trans with passon od gearset yesterday in a 66 b body.it wont stay in 3rd gear,I flipped my stock arm with stock rod but Im thinking maybe I need a special rod and or rod/arm combo for this?
Re: does the passon O/D 4 speed gearset require special 3-4 rod? [Re: ogopogo] #2489661
04/29/18 08:16 PM
04/29/18 08:16 PM
Abilene, Texas
fastmark Online content
fastmark  Online Content
Abilene, Texas
Yes you need a new 3-4 rod. Jamie supplies it with the gears. Brewers does not.
Re: does the passon O/D 4 speed gearset require special 3-4 rod? [Re: ogopogo] #2489788
04/30/18 12:54 AM
04/30/18 12:54 AM
southeast NE
lemondana Offline
lemondana  Offline
southeast NE
Let us know how you like it once you get the bugs worked out. Thanks-
Re: does the passon O/D 4 speed gearset require special 3-4 rod? [Re: ogopogo] #2489867
04/30/18 10:10 AM
04/30/18 10:10 AM
Abilene, Texas
Abilene, Texas
I’ve done two for customers and both like the gear ratios. One is a 3.54 and he drives it on the highway. The other is a 4.10 Dana car and it makes it easier to drive for sure.
Re: does the passon O/D 4 speed gearset require special 3-4 rod? [Re: fastmark] #2490037
04/30/18 03:53 PM
04/30/18 03:53 PM
BC Canada
O
ogopogo Offline OP
ogopogo  Offline OP
O
BC Canada
spoke to Jamie and he figures crappy bell alignment has bitten me,,,,,,again.....just ordered a browell tool like i should have done years ago!
Re: does the passon O/D 4 speed gearset require special 3-4 rod? [Re: ogopogo] #2491339
05/03/18 09:39 AM
05/03/18 09:39 AM
N/E, Michigan
RATTRAP Offline
RATTRAP  Offline
N/E, Michigan
A dial indicator and a mag base would have been a better investment. IMO
And the use of offset dowels and or Dowel the bell to the block @ assy after its dialed in.
Re: does the passon O/D 4 speed gearset require special 3-4 rod? [Re: RATTRAP] #2491346
05/03/18 10:02 AM
05/03/18 10:02 AM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
A magnetic base doesn't work as fast or as well as the Browell tool does. I have a tool base that was made to bolt to the crank flange and it's more solid than a mag base indicator twocents
Gus beer
64 Plymouth Savoy
Dana 60
