Fuel cell question
#2482417
04/14/18 02:34 AM
04/14/18 02:34 AM
Posts: 1,458 Martinsville, IN
cdwmotorsports
Martinsville, IN
I had/have a 15 gallon Triangle Engineering fuel cell that when I was removing an AN fitting from it the last three threads on the fitting destroyed themselves and the first three threads of the bung in the fuel cell. I am now looking at replacements and saw these on eBay... Fuel cell My question is does anyone have experience with these? Worth the gamble or no? I really like the aluminum one I had but unless it can have the bad bung welded up I see no likelihood of saving it.
eBay-cdwmotorsports
Re: Fuel cell question
[Re: 340Cuda]
#2482548
04/14/18 01:07 PM
04/14/18 01:07 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Start blowing air through it.. once you cant smell fuel you can cut off the fittings that are galled and weld on new ones.. I weld alum so its cheap for me.. if you have foam in it pull that out before welding.. to weld the fittings on is pretty quick EDIT Make sure the tank is clean.. no paint
[Re: MR_P_BODY]
#2482748
04/14/18 09:51 PM
04/14/18 09:51 PM
cdwmotorsports
Martinsville, IN
Can you drill and tap the bung for a larger size thread? Doug I have considered this but not sure what size I would go to, I think it has 10AN to maybe 1/2"NPT bungs in it already A good brand of never seize is your friend on aluminum to aluminum fittings LOL where were you 15 years ago? It did have thread tape on it but that clearly didn't help it Start blowing air through it.. once you cant smell fuel you can cut off the fittings that are galled and weld on new ones.. I weld alum so its cheap for me.. if you have foam in it pull that out before welding.. to weld the fittings on is pretty quick EDIT Make sure the tank is clean.. no paint Its a bare Aluminum cell so I have considered this I will check it out further, thanks for all the help/suggestions guys.
eBay-cdwmotorsports
[Re: 340Cuda]
#2482751
04/14/18 09:56 PM
04/14/18 09:56 PM
cdwmotorsports
Martinsville, IN
I do try to use antiseize on anything aluminum and my experience is often the same as the gentleman below: So do I not have to use thread sealer on the NPT side of these fittings? Fuel tank, regulator and pump are all aluminum bodied
eBay-cdwmotorsports
[Re: cdwmotorsports]
#2482778
04/14/18 11:00 PM
04/14/18 11:00 PM
Posts: 22,696 Bitopia
jcc
Bitopia
I didn't see where you mentioned the cell had ever had fuel in it. You could install a bulkhead fitting I suspect elsewhere and just plug and epoxy the partial threads left over and skip the welding solution. The fuel cell link sounds/looks decent, almost priced too low, makes me wonder as if it's up to expected standards. Who will go first?
#2482783
04/14/18 11:16 PM
04/14/18 11:16 PM
MR_P_BODY
This is what I built for my Rampage.. its 17 gals with 2 #10 fittings on the bottom, a vent and a fuel gauge.. works perfect
#2482848
04/15/18 12:58 AM
04/15/18 12:58 AM
Posts: 6,257 gulfport, ms, west mi
rowin4
Both of my aluminum fuel cells have 1/2" NPT . A 1/2 " bulkhead fitting might be the best way to go. Tapping to 3/4"NPT would be questionable on how much material there would be left to tap.
[Re: jcc]
#2483024
04/15/18 12:51 PM
04/15/18 12:51 PM
cdwmotorsports
Martinsville, IN
I didn't see where you mentioned the cell had ever had fuel in it. You could install a bulkhead fitting I suspect elsewhere and just plug and epoxy the partial threads left over and skip the welding solution. The fuel cell link sounds/looks decent, almost priced too low, makes me wonder as if it's up to expected standards. Who will go first? Has sold 104 of them and the reviews are all good.... dunno
eBay-cdwmotorsports
