'71 Roadrunner Air Grabber #2454930
02/21/18 02:43 AM
02/21/18 02:43 AM
Herndon VA
I
intruder71 Offline OP
I
Herndon VA
I recently bought a 71 RR with a 415 stroker motor and dual quads. The guts of the Air Grabber were removed to make room for the 415 Stroker. The Air Grabber is held in the "up" position with a few screws that I can remove. I'd like to make the Air Grabber functional with a small servo motor. Does anyone have any ideas on how to attach a small electric or hydraulic motor with a switch inside the car so that I can raise/lower the AG? Thanks.
Re: '71 Roadrunner Air Grabber [Re: intruder71] #2455900
02/23/18 12:11 AM
02/23/18 12:11 AM
Western Washington
Sixgun Offline
Sixgun  Offline
Western Washington
easiest thing comes to mind is a window lift motor off a ricer. 12 volt and something you could find in pull a part. get a switch and a pigtail off the same car.Unsure of what make would have a usable mechanism and not a cable or tape drive...but even those could work.Good luck bud!
I'm 55 now, no time to waste. Not a week goes by that I don't hear about someone passing on.Let's get out there,smoke some tires,have a beer with a good friend,do what you have always wanted to do.I am pretty sure no one will ever say on their deathbed "gee I'm glad my life was calm and boring"
Re: '71 Roadrunner Air Grabber [Re: intruder71] #2455944
02/23/18 01:34 AM
02/23/18 01:34 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
I think I would see if one of those power trunk latches has enough movement. Some of the Caddy's & Lincolns had a couple inches of travel. You could connect one between the hood and the scoop door. Gene
Re: '71 Roadrunner Air Grabber [Re: intruder71] #2456038
02/23/18 10:55 AM
02/23/18 10:55 AM
Sault Ste. Marie, Ontario, Can...
moparmike1 Online content
moparmike1  Online Content
If you're on Facebook, join the '71 - 74 roadrunner/charger owners group' page. There is a post from Ronny Conklin on February 22, 2018, describing exactly what you're looking for. He did it with a remote control car servo.
Mike.
Re: '71 Roadrunner Air Grabber [Re: intruder71] #2456166
02/23/18 02:51 PM
02/23/18 02:51 PM
Herndon VA
I
I
Herndon VA
Thanks for the replies. I'll look into these options. Please keep the ideas coming.
Re: '71 Roadrunner Air Grabber [Re: intruder71] #2456203
02/23/18 03:56 PM
02/23/18 03:56 PM
JERSEY
RJS Online work
RJS  Online Work
JERSEY
Yep as Mike already stated that guy on facebook made it look easy!!!
Ron
Re: '71 Roadrunner Air Grabber [Re: intruder71] #2456217
02/23/18 04:14 PM
02/23/18 04:14 PM
Chicago
PurpleBeeper Offline
Chicago
I know you're looking for a servo, but why not just hook up the air grabber the way the factory did???? I mean, because you're motor is a stroker doesn't make it any larger on the outside.
Unless I'm missing something (?) you could just put the air grabber stuff back in & have it work like the factory intended. The ONLY thing I would be concerned about is the carb/carb spacing on the intake manifold & the overall height of the intake.
Your hood closes, right? The air grabber box is in there, right? If not, then "maybe" consider an old 413 dual quad cast iron intake or an Offenhauser low-rise dual quad intake.
The only big question I have is, "Will a hemi dual quad air grabber air cleaner fit my dual quad carbs?" I thought about running a dual quad on my '70 Roadrunner many times, but never had a hemi air cleaner base (or knew the carb spacing) to check. As long as the hemi air grabber base fits your carbs & your hood closes, you can run a factory air grabber setup.
70 Roadrunner convt. street car 440+6, NOS, 4-spd, SS springs '96 Mustang GT convt. street car '04 4.6 SOHC, NOS, auto, lowered "Officer, that button is for short on-ramps"
Re: '71 Roadrunner Air Grabber [Re: intruder71] #2456268
02/23/18 06:36 PM
02/23/18 06:36 PM
Herndon VA
I
I
Herndon VA
None of the air grabber parts are with the car. frown
Re: '71 Roadrunner Air Grabber [Re: PurpleBeeper] #2456475
02/24/18 01:49 AM
02/24/18 01:49 AM
Western Washington
Sixgun Offline
Sixgun  Offline
Western Washington
The factory spacing for the carters is real close together, too close for holley 600's. Depends on your DQ manifold, but most of those I have seen were set up with the wider spacing to accept either carter, (eddy) or holley with the side hung bowls (600 single feed style). I have the stage 5 on my 572 and butchered a repop 'glass AG base and mated it with two cheap aluminum drop bases from jegs. FHO has a real nice metal (IIRC) base for stage 5 intake but it's like 550.
