Re: 318 harmonic balancer questions...
[Re: plazomat]
#2441193
01/26/18 09:11 PM
01/26/18 09:11 PM
RapidRobert
I wrote myself a note to get the ID for you tomorrow.
[Re: roadrunninMark]
#2441290
01/27/18 12:18 AM
01/27/18 12:18 AM
Posts: 643 Toronto, Ontario, Canada
plazomat
Plazomat.... are you making the EFI from an existing system? I have a very slow moving project that it coming close...but it has been for a few years. What I have done is take the TBI system from a 350 Chebby and modded the ECU/computer with a megasquirt MS2 processor board. Stage 1 will be running HEI ignition - triggered from a lean burn distributor. Stage 2 will be using LS2 coils mounted on the valve covers running in wasted spark - thus I need a crank mount trigger wheel to get crank position information into the modded ECU. I really hope to be running stage 1 by the end of this summer. Plaz
[Re: plazomat]
#2441708
01/27/18 08:51 PM
01/27/18 08:51 PM
RapidRobert
I got roughly 1.532" on the crank snout & roughly 1.540" on the dampener ID"
[Re: plazomat]
#2441830
01/28/18 12:05 AM
01/28/18 12:05 AM
RapidRobert
not a bit bro, glad to do it
[Re: RTSrunner]
#2441932
01/28/18 01:57 AM
01/28/18 01:57 AM
RapidRobert
& I ended up doing several hours of eng work out there today while I was at it otherwise I woulda ended up just layeing in bed all day watching tv (exc for a 6 mile jog) so everybody came out ahead.
[Re: RapidRobert]
#2442335
01/28/18 05:50 PM
01/28/18 05:50 PM
plazomat
& I ended up doing several hours of eng work out there today while I was at it otherwise I woulda ended up just layeing in bed all day watching tv (exc for a 6 mile jog) so everybody came out ahead. It's a win win.
[Re: moparx]
#2442343
01/28/18 06:05 PM
01/28/18 06:05 PM
RapidRobert
I got roughly 1.532" on the crank snout & roughly 1.540" on the dampener ID" not to be a party pooper, but shouldn't the damper be a press fit on the crank ? with .008 bigger id on the damper, that thing would fall on the crank snout sideways ! what am i missing here ? these were with some plastic calipers, I can mike the snout dead on with a regular mike if needed, the dampener ID was rusty. I was assuming we only needed a "close" measurement
[Re: moparx]
#2442855
01/29/18 01:49 PM
01/29/18 01:49 PM
RapidRobert
You're fine bro & in fact I am gonna go out there in a few minutes & get an exact measurement. Plus I might of transposed em as I wrote the 2 numbers on my hand then I came in & without thinking washed my hands then saw that the numbers were barely legible. (the whole day went like that!) EDIT I got 1.532" on the snout with a mike & I cant find my snap gauges so I tried the plastic calipers again on the dampener ID & got 1&9/16 (1.5625"), the edges on the calipers ain't rounded to match the concave circular ID so that (plastic caliper)reading is inaccurate.
