318 harmonic balancer questions... #2440224
01/24/18 09:07 PM
01/24/18 09:07 PM
Toronto, Ontario, Canada
plazomat Offline OP
plazomat  Offline OP
Hi There,
Can anyone help me out with the outer dimensions of the 1968ish 318 harmonic balancer? I can't get to the car for a while to pull the balancer off and measure it...I am designing a 36-1 trigger wheel for EFI conversion.
Plaz
Re: 318 harmonic balancer questions... [Re: plazomat] #2440858
01/26/18 03:12 AM
01/26/18 03:12 AM
plazomat Offline OP
plazomat  Offline OP
BTT
Re: 318 harmonic balancer questions... [Re: plazomat] #2440876
01/26/18 04:25 AM
01/26/18 04:25 AM
Pittsburgh,PA
RTSrunner Offline
RTSrunner  Offline
Pittsburgh,PA
What measurements do you need,diameter,circumference,etc.? I have a couple '67 318's one out and one in my van.As long as it is on engine measurements I can get themfor you.Off location so it may take a day or two though.
Re: 318 harmonic balancer questions... [Re: plazomat] #2440999
01/26/18 02:35 PM
01/26/18 02:35 PM
plazomat Offline OP
plazomat  Offline OP
Thanks RTS - hoping for outside diameter at least. If I could get the diameter of the center hole the crank goes through that would be awesome.
Plaz
Re: 318 harmonic balancer questions... [Re: plazomat] #2441004
01/26/18 02:42 PM
01/26/18 02:42 PM
OD is 7&1/4"
Re: 318 harmonic balancer questions... [Re: RapidRobert] #2441180
01/26/18 08:34 PM
01/26/18 08:34 PM
plazomat Offline OP
plazomat  Offline OP
Thanks Robert..
Re: 318 harmonic balancer questions... [Re: plazomat] #2441193
01/26/18 09:11 PM
01/26/18 09:11 PM
I wrote myself a note to get the ID for you tomorrow.
Re: 318 harmonic balancer questions... [Re: plazomat] #2441204
01/26/18 09:41 PM
01/26/18 09:41 PM
GA
roadrunninMark Offline
GA
Plazomat.... are you making the EFI from an existing system?
Re: 318 harmonic balancer questions... [Re: RapidRobert] #2441285
01/27/18 12:11 AM
01/27/18 12:11 AM
plazomat Offline OP
plazomat  Offline OP
That would be awesome Robert - can't thank you enough.
Re: 318 harmonic balancer questions... [Re: roadrunninMark] #2441290
01/27/18 12:18 AM
01/27/18 12:18 AM
plazomat Offline OP
plazomat  Offline OP
I have a very slow moving project that it coming close...but it has been for a few years.
What I have done is take the TBI system from a 350 Chebby and modded the ECU/computer with a megasquirt MS2 processor board.
Stage 1 will be running HEI ignition - triggered from a lean burn distributor.
Stage 2 will be using LS2 coils mounted on the valve covers running in wasted spark - thus I need a crank mount trigger wheel to get crank position information into the modded ECU.
I really hope to be running stage 1 by the end of this summer.
Plaz
Re: 318 harmonic balancer questions... [Re: plazomat] #2441708
01/27/18 08:51 PM
01/27/18 08:51 PM
I got roughly 1.532" on the crank snout & roughly 1.540" on the dampener ID"
Re: 318 harmonic balancer questions... [Re: RapidRobert] #2441807
01/27/18 11:35 PM
01/27/18 11:35 PM
plazomat Offline OP
plazomat  Offline OP
Thanks Robert - hope it wasn't too much trouble.
Plaz
Re: 318 harmonic balancer questions... [Re: plazomat] #2441830
01/28/18 12:05 AM
01/28/18 12:05 AM
not a bit bro, glad to do it
Re: 318 harmonic balancer questions... [Re: plazomat] #2441838
01/28/18 12:17 AM
01/28/18 12:17 AM
Pittsburgh,PA
RTSrunner Offline
RTSrunner  Offline
Pittsburgh,PA
Looks like Robert saved me a trip to the storage garage!
Re: 318 harmonic balancer questions... [Re: RTSrunner] #2441932
01/28/18 01:57 AM
01/28/18 01:57 AM
& I ended up doing several hours of eng work out there today while I was at it otherwise I woulda ended up just layeing in bed all day watching tv (exc for a 6 mile jog) so everybody came out ahead.
Re: 318 harmonic balancer questions... [Re: RapidRobert] #2442188
01/28/18 01:30 PM
01/28/18 01:30 PM
moparx Online content
moparx  Online Content
not to be a party pooper, but shouldn't the damper be a press fit on the crank ? with .008 bigger id on the damper, that thing would fall on the crank snout sideways ! what am i missing here ?
beer
Re: 318 harmonic balancer questions... [Re: RapidRobert] #2442335
01/28/18 05:50 PM
01/28/18 05:50 PM
plazomat Offline OP
plazomat  Offline OP
It's a win win.
Re: 318 harmonic balancer questions... [Re: moparx] #2442343
01/28/18 06:05 PM
01/28/18 06:05 PM
beer
these were with some plastic calipers, I can mike the snout dead on with a regular mike if needed, the dampener ID was rusty. I was assuming we only needed a "close" measurement
Re: 318 harmonic balancer questions... [Re: RapidRobert] #2442842
01/29/18 01:08 PM
01/29/18 01:08 PM
sorry if i came off as doubting you RR. i missed the "rough idea" part. in the future, i'll try to read more closely !
beer
Re: 318 harmonic balancer questions... [Re: moparx] #2442855
01/29/18 01:49 PM
01/29/18 01:49 PM
You're fine bro & in fact I am gonna go out there in a few minutes & get an exact measurement. Plus I might of transposed em as I wrote the 2 numbers on my hand then I came in & without thinking washed my hands then saw that the numbers were barely legible. (the whole day went like that!) EDIT I got 1.532" on the snout with a mike & I cant find my snap gauges so I tried the plastic calipers again on the dampener ID & got 1&9/16 (1.5625"), the edges on the calipers ain't rounded to match the concave circular ID so that (plastic caliper)reading is inaccurate.
