Re: heard contradicting news about plastic timing chain gears?
[Re: Sport440]
#2433812
01/13/18 11:20 AM
01/13/18 11:20 AM
Posts: 21,055 in a cattle trailer down by th...
Guitar Jones
Car had 30K from the original owner, only about 3k a year. Second owner now put another 16k on the counter. New tires. Brakes all around were put on three years back, but he only drives it a few miles here and there. AC works. Body is straight. I will see . Also, what new car are we talking about maybe?? Apparently it's a closely guarded secret.
"Come get your wife"
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Front and rear disc and hydroboost conversion. 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
[Re: moparpollack]
#2433854
01/13/18 12:55 PM
01/13/18 12:55 PM
Posts: 1,897 Spahn Ranch
RMCHRGR
Spahn Ranch
If you only knew a guy with a tow truck that could haul it for you. He might...
'71 Duster '72 Challenger '17 Ram 1500
[Re: fullmetaljacket]
#2433856
01/13/18 12:57 PM
01/13/18 12:57 PM
RMCHRGR
Spahn Ranch
More door B bodies can be cool in a '70's TV cop show sorta way.
#2434023
01/13/18 06:46 PM
01/13/18 06:46 PM
crabman173
crabman173
I really think 4 doors are the next wave I remember when wagons and C Bods were donors and junkers but hey TTI makes headers for C Bods now so only matter of time until 4 Doors is all some can or want to afford You let me see a good one cheap and I will jump on it
#2435315
01/15/18 11:40 PM
01/15/18 11:40 PM
Posts: 17,928 Akron, Ohio
ProSport
Akron, Ohio
Did the nylon gears come in low deck 383's? When I was a teenager I had a 383 '69 Coronet. Constantly got towed home due to loss of oil pressure. I was told the oil pickup and/or oil passages were getting clogged with nylon pieces. Sold car and never opened the engine up to look.
[Re: ProSport]
#2435558
01/16/18 12:40 PM
01/16/18 12:40 PM
Posts: 20,235 north of coder
moparx
yep. 383's got 'em too. i have a set still on the shelf from a 15k, 69 engine that looks like new. that set was taken out when this particular engine was "day two'ed", headers, dp4b intake/780 holley, racer brown ssh25 cam, roller chain and re-curved distributor. my 66 charger had that set as well. it went by,by with ???k, so i replaced it with a 413. that inland shifter sucked. was replaced with a hurst comp+, but i quickly found out i can't shift for s**t. these were "back in the day" when these cars were almost new.
