Re: heard contradicting news about plastic timing chain gears? [Re: Sport440] #2433812
01/13/18 11:20 AM
01/13/18 11:20 AM
Guitar Jones Offline
Originally Posted By Sport440
Originally Posted By fullmetaljacket
Car had 30K from the original owner, only about 3k a year. Second owner now put another 16k on the counter.
New tires.
Brakes all around were put on three years back, but he only drives it a few miles here and there. AC works. Body is straight. I will see .
Also, what new car are we talking about maybe?? up
Apparently it's a closely guarded secret. laugh2
Re: heard contradicting news about plastic timing chain gears? [Re: Sport440] #2433851
01/13/18 12:41 PM
01/13/18 12:41 PM
fullmetaljacket Offline OP
Closely guarded secret is that I finally took in some sleep while you guys hammered away. LOL.
The car is a 4 door 71' Coronet. 318 with air, crank up windows just the way I like 'em and bench seat.
I must admit, I Like the Satellites and Sebrings better with their handsome looks for the grill area and rear lights/bumper.
Re: heard contradicting news about plastic timing chain gears? [Re: moparpollack] #2433854
01/13/18 12:55 PM
01/13/18 12:55 PM
Spahn Ranch
RMCHRGR Offline
RMCHRGR  Offline
Spahn Ranch
Originally Posted By moparpollack
If you only knew a guy with a tow truck that could haul it for you. work
He might...
'71 Duster
'72 Challenger
'17 Ram 1500
Re: heard contradicting news about plastic timing chain gears? [Re: fullmetaljacket] #2433856
01/13/18 12:57 PM
01/13/18 12:57 PM
Spahn Ranch
RMCHRGR Offline
RMCHRGR  Offline
Spahn Ranch
More door B bodies can be cool in a '70's TV cop show sorta way.
'71 Duster
'72 Challenger
'17 Ram 1500
Re: heard contradicting news about plastic timing chain gears? [Re: fullmetaljacket] #2434023
01/13/18 06:46 PM
01/13/18 06:46 PM
crabman173
crabman173
I really think 4 doors are the next wave
I remember when wagons and C Bods were donors and junkers but hey TTI makes headers for C Bods now so only matter of time until 4 Doors is all some can or want to afford You let me see a good one cheap and I will jump on it
Re: heard contradicting news about plastic timing chain gears? [Re: fullmetaljacket] #2435132
01/15/18 06:51 PM
01/15/18 06:51 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Not really related, but did several small block Chevy engines where the timing chain was so loose it wore holes in the timing chain cover. Those covers are alot cheaper than small block Mopar covers.
Re: heard contradicting news about plastic timing chain gears? [Re: fullmetaljacket] #2435244
01/15/18 10:00 PM
01/15/18 10:00 PM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
Look at it this way, if you drive it and it doesn't make it, it will be cheaper to ship the rest of the way! Throw an alternator in your suitcase and go get it!
Re: heard contradicting news about plastic timing chain gears? [Re: fullmetaljacket] #2435249
01/15/18 10:15 PM
01/15/18 10:15 PM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
It's a concern if you are going to drive a car cross country after buying it and just a measure of insurance.
Probably ought to replace it soon.
https://www.forcbodiesonly.com/mopar-for...45/#post-508844
'68 Fury Convertible
'69 300 Convertible
'15 Durango 5.7 Hemi
'16 300 S Hemi
Re: heard contradicting news about plastic timing chain gears? [Re: fullmetaljacket] #2435315
01/15/18 11:40 PM
01/15/18 11:40 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Did the nylon gears come in low deck 383's?
When I was a teenager I had a 383 '69 Coronet. Constantly got towed home due to loss of oil pressure.
I was told the oil pickup and/or oil passages were getting clogged with nylon pieces. Sold car and never opened the engine up to look.
Re: heard contradicting news about plastic timing chain gears? [Re: ProSport] #2435558
01/16/18 12:40 PM
01/16/18 12:40 PM
moparx Offline
moparx  Offline
yep. 383's got 'em too. i have a set still on the shelf from a 15k, 69 engine that looks like new. that set was taken out when this particular engine was "day two'ed", headers, dp4b intake/780 holley, racer brown ssh25 cam, roller chain and re-curved distributor. my 66 charger had that set as well. it went by,by with ???k, so i replaced it with a 413. that inland shifter sucked. was replaced with a hurst comp+, but i quickly found out i can't shift for s**t. laugh2 these were "back in the day" when these cars were almost new.
beer
Re: heard contradicting news about plastic timing chain gears? [Re: fullmetaljacket] #2435575
01/16/18 12:54 PM
01/16/18 12:54 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Bottom line is those gears are good for usually at least 100,000, but with their age, all bets are off. I like them cause they are quite, but are really hard to find new now.
