Re: Slant/6 Torsion Bars B-Body or .920 or .960 Mopar Perform?
[Re: lockjaw-express]
#2431530
01/09/18 11:41 AM
01/09/18 11:41 AM
Posts: 562 Ohio
lockjaw-express
Ohio
I also do NOT plan on running an Anti-Roll bar on the front, since I do want some lift for weight transfer on launch...still a street strip and the car does weigh 3500 lbs.
When I replace the front strut bars, they were bent quite a bit, and I think that street driving with the slant/6 bars at such a droop may have caused it?
Mark
#2431602
01/09/18 02:16 PM
01/09/18 02:16 PM
RapidRobert
I used massive circle track t bars (all I had ex for some /6 bars) on a SB daily driver 65 dart (002/003 springs) & it rode high & tight. It was good
#2431688
01/09/18 05:00 PM
01/09/18 05:00 PM
Posts: 43,308 Bend,OR USA
Cab_Burge
Buy the 318 B body torsion bars if you want a higher ride height and still have a lot of front end rise at WOT
#2432066
01/10/18 03:52 AM
01/10/18 03:52 AM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
Verifying for reference: Is the .920 considered a stock small block bar, and .960 a big block bar? Or is it more complicated than this?
[Re: StealthWedge67]
#2432148
01/10/18 12:51 PM
01/10/18 12:51 PM
Posts: 2,094 central texas
krautrock
central texas
Verifying for reference: Is the .920 considered a stock small block bar, and .960 a big block bar? Or is it more complicated than this? small block bar is more like .860 or .870 my 67 coronet had the factory 318 bars in and i couldn't get the pass side very far off the bump stop after i put SS springs on the car. i put some .960 bars on it and some bilstein shocks and the front is pretty dang firm now. according to this, my bars should've been .880" http://www.forbbodiesonly.com/moparforum/attachments/torsion-252520bars-jpg.282689/383/426 bars are .900" 440/hemi bars are .920" Improved handling is .960" there is also this chart... ![](http://www.moparts.org/Tech/Archive/susp/img/tbchrt02.JPG)
#2437298
01/19/18 02:49 AM
01/19/18 02:49 AM
Posts: 1,107 Massillon, Ohio
cudatom
Massillon, Ohio
I have the 318 Tbars on my wagon. This is a big block car and at 4000lbs. The adjusteres are set at about 50%. These are also 50 yrs old. I also drive on the street w/caltracs. No problem. The only item for street driving I may change out is the front shocks. The Rancho front shocks really come up fast even under light excelleration.
Ok
