Slant/6 Torsion Bars B-Body or .920 or .960 Mopar Perform? #2431453
01/09/18 02:47 AM
01/09/18 02:47 AM
Ohio
lockjaw-express Offline OP
Ohio
I have the Slant/6 Torsion Bars in my ‘69 GTX, and the front end is just to low, and is at the end of the adjusters...wont go any higher.
Since my car is a street/strip car should I buy the .920 MP Torsion bar, which may be a little stiffer than my current TB set, that I think is what Mopar Performance calls the “Hemi Torsion Bars”, or just go with the .960 (stock Ride Height), but still the Mopar performance bar.
Thank you for any advise you all might have!
Mark
Re: Slant/6 Torsion Bars B-Body or .920 or .960 Mopar Perform? [Re: lockjaw-express] #2431530
01/09/18 11:41 AM
01/09/18 11:41 AM
Ohio
Ohio
I also do NOT plan on running an Anti-Roll bar on the front, since I do want some lift for weight transfer on launch...still a street strip and the car does weigh 3500 lbs.
When I replace the front strut bars, they were bent quite a bit, and I think that street driving with the slant/6 bars at such a droop may have caused it?
Mark
Re: Slant/6 Torsion Bars B-Body or .920 or .960 Mopar Perform? [Re: lockjaw-express] #2431602
01/09/18 02:16 PM
01/09/18 02:16 PM
I used massive circle track t bars (all I had ex for some /6 bars) on a SB daily driver 65 dart (002/003 springs) & it rode high & tight. It was good
Re: Slant/6 Torsion Bars B-Body or .920 or .960 Mopar Perform? [Re: lockjaw-express] #2431651
01/09/18 03:35 PM
01/09/18 03:35 PM
Ohio
Ohio
Thanks Robert, but I just want to order a set of bars that will support my front end, and still allow some travel for launch at the strip...just a good set of all around bars.
Mancini sells 3-4 sets of Mopar Performance torsion bars.
Mark
Re: Slant/6 Torsion Bars B-Body or .920 or .960 Mopar Perform? [Re: lockjaw-express] #2431688
01/09/18 05:00 PM
01/09/18 05:00 PM
Buy the 318 B body torsion bars if you want a higher ride height and still have a lot of front end rise at WOT twocents
Re: Slant/6 Torsion Bars B-Body or .920 or .960 Mopar Perform? [Re: lockjaw-express] #2431733
01/09/18 06:46 PM
01/09/18 06:46 PM
A727Tflite Offline
A727Tflite  Offline
Sway bar has little if any effect on front end lift on the drag strip. Sure makes the car handle better on the street.
Go with a standard B body RB engine torsion bar and a looser extension shock and forget about it.
Spend time getting the rear suspension to hook the car.
Re: Slant/6 Torsion Bars B-Body or .920 or .960 Mopar Perform? [Re: lockjaw-express] #2431746
01/09/18 07:03 PM
01/09/18 07:03 PM
Ohio
Ohio
I have caltracs, mono leafs, spring sliders, and caltrac front shocks. I also have caltrac front shocks.
I just want to select the right Mopar Performance torsion bar set that I can drive on the street too.
thanks transman, cab, and all!
Here is the link:
http://www.manciniracing.com/search-resu...p;Submit=Search
Re: Slant/6 Torsion Bars B-Body or .920 or .960 Mopar Perform? [Re: lockjaw-express] #2431791
01/09/18 08:20 PM
01/09/18 08:20 PM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
just doing regular slow poke street driving and then some drag racing, i would run the .920 bars.
Re: Slant/6 Torsion Bars B-Body or .920 or .960 Mopar Perform? [Re: lockjaw-express] #2432066
01/10/18 03:52 AM
01/10/18 03:52 AM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
Verifying for reference: Is the .920 considered a stock small block bar, and .960 a big block bar? Or is it more complicated than this?
Re: Slant/6 Torsion Bars B-Body or .920 or .960 Mopar Perform? [Re: lockjaw-express] #2432073
01/10/18 04:50 AM
01/10/18 04:50 AM
Ohio
Ohio
Good point StealthWedge67!
Re: Slant/6 Torsion Bars B-Body or .920 or .960 Mopar Perform? [Re: StealthWedge67] #2432092
01/10/18 09:34 AM
01/10/18 09:34 AM
Prospect, PA
BSB67 Online content
BSB67  Online Content
Prospect, PA
.920" big block bar.
Re: Slant/6 Torsion Bars B-Body or .920 or .960 Mopar Perform? [Re: StealthWedge67] #2432148
01/10/18 12:51 PM
01/10/18 12:51 PM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
small block bar is more like .860 or .870
my 67 coronet had the factory 318 bars in and i couldn't get the pass side very far off the bump stop after i put SS springs on the car.
i put some .960 bars on it and some bilstein shocks and the front is pretty dang firm now.
according to this, my bars should've been .880"
http://www.forbbodiesonly.com/moparforum/attachments/torsion-252520bars-jpg.282689/
383/426 bars are .900"
440/hemi bars are .920"
Improved handling is .960"
there is also this chart...
Re: Slant/6 Torsion Bars B-Body or .920 or .960 Mopar Perform? [Re: lockjaw-express] #2432152
01/10/18 01:02 PM
01/10/18 01:02 PM
N/E, Michigan
RATTRAP Offline
RATTRAP  Offline
N/E, Michigan
I would replace the worn /6 torsion bars with a new set of /6 torsion bars.
Re: Slant/6 Torsion Bars B-Body or .920 or .960 Mopar Perform? [Re: lockjaw-express] #2432203
01/10/18 02:43 PM
01/10/18 02:43 PM
Ohio
Ohio
The slant 6 bars are fairly new, however it looks like the .920 or .960 bar would give a better ride height.
I think I will go with the .920 bars, since I drive the car on the street, unless I hear a reason that I should go with the .960 bars.
Thank you for all of the advice!
Re: Slant/6 Torsion Bars B-Body or .920 or .960 Mopar Perform? [Re: lockjaw-express] #2437293
01/19/18 02:31 AM
01/19/18 02:31 AM
Ohio
Ohio
Bought the Mopar Performance .960 bars from Jegs today, and I have a couple of questions:
1) with the adjusters all the way out, do I put the bars in so the line on the back of the bar is vertical?
2) I read where they want the lower bumper stop removed prior to install???
3) any other pointers would be very helpful...
Thank you all!
Mark
PS: also bought the QA1 Tubular upper control arms to get the extra 3* of castor for better high speed stability.
Re: Slant/6 Torsion Bars B-Body or .920 or .960 Mopar Perform? [Re: lockjaw-express] #2437298
01/19/18 02:49 AM
01/19/18 02:49 AM
Massillon, Ohio
cudatom Offline
cudatom  Offline
Massillon, Ohio
I have the 318 Tbars on my wagon. This is a big block car and at 4000lbs. The adjusteres are set at about 50%. These are also 50 yrs old. I also drive on the street w/caltracs. No problem. The only item for street driving I may change out is the front shocks. The Rancho front shocks really come up fast even under light excelleration.
Ok
Re: Slant/6 Torsion Bars B-Body or .920 or .960 Mopar Perform? [Re: lockjaw-express] #2437336
01/19/18 06:06 AM
01/19/18 06:06 AM
Disconnect the lower ball joint(remove the bolts to the spindle) so the lower control arm will drop down as much as needed to install those new bars without fighting them up scope twocentsZ Back both adjusters all the way out first also wrench
As far as the lines I think they need to be towards the trans cross member, not to the K member and on the alignment I am no help on that. I have never seen anything in any of the FSM about positioning them a set way confused
Make sure and put the L bar on the drivers side, R bar on the other side grin
Re: Slant/6 Torsion Bars B-Body or .920 or .960 Mopar Perform? [Re: lockjaw-express] #2437433
01/19/18 01:21 PM
01/19/18 01:21 PM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
make sure the bars are on the correct side, there is a L and R bar, the part numbers will be different.
the hexes are indexed a little and if you swap them your ride height will be all wrong.
i have done like Cab mentioned and unbolted the spindle from the ball joint to get travel in the lower arm, but i was swapping strut rods so the whole arm had to slide almost all the way out.
i think if i removed the upper bump stop that would've dropped the lower control arms enough to slide the bars in.
i usually just install the bars so the line in the bar is vertical.
when it's in the rear crossmember.
don't forget to the do the final torque on the LCA nuts and the strut rods when the car is at ride height.
there is a service manual method for setting ride height.
if i rememeber correctly, you measure from the ground to the lowest point on the lower control arm torsion bar pivot arm, the little arm that rides on the ride height screw. measure from the bottom of that round part that is sandwiched in between the sides of the LCA.
and also measure from the ground to the bottom of the lower ball joint.
the difference should be 1-1/8" roughly...
Re: Slant/6 Torsion Bars B-Body or .920 or .960 Mopar Perform? [Re: lockjaw-express] #2437438
01/19/18 01:32 PM
01/19/18 01:32 PM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
oh you are swapping the upper control arms.
just slide the torsion bars in the LCA when the upper arms are unbolted.
make sure the adjusters are the screwed all the way out so they are loose in the arm. the LCA will rotate down until it touches the K-member.
from there, you should be able to rotate down torsion bar pivot blade in the LCA by hand, that makes it easy to align the hexes on the bar and LCA socket.
if they are hard to rotate then I would also loosen the bolts on LCA pivot pin to make it easier.
The torsion bars don't really have a front/rear, but i install them so i can see the part number at the torsion bar crossmember.
once the torsion bars are starting to slide in the arms, the hexes are aligned and all that, i use a piece of wood in the rear of the bar, tap it with a hammer to slide the bars into the sockets.
I also clean the sockets out and put a some fresh clean grease in there.
Re: Slant/6 Torsion Bars B-Body or .920 or .960 Mopar Perform? [Re: lockjaw-express] #2437575
01/19/18 06:07 PM
01/19/18 06:07 PM
Ohio
Ohio
One other question I have, should I run the tubular front sway bar, since the car is a street strip car? Hotchkis make a tubular lighter weight bar kit that looks very nice?
Any thoughts?
Thank you, Mark
