BATTERY QUESTION............ #2425465
12/29/17 07:01 PM
12/29/17 07:01 PM
State of confusion
Thumperdart Offline OP
State of confusion
After my removing of the second battery in my dart cos it was 11+ years old, I went w/a 1000 cca single battery and as before my 60 ft suffered from a 1.33 to a 1.40 so, can any other battery w/less cca's be added w/out issues or do I need a duplicate of the other........... beer
Re: BATTERY QUESTION............ [Re: Thumperdart] #2425470
12/29/17 07:08 PM
12/29/17 07:08 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
Throw the alternator and big battery in the trash.. and by good shocks.. and welcome to the 1.20 60-foot Club.. I went from a 1.25 ish 60 foot to a 1.19 average.. and now the smart people tell me to move the fuel cell to the front too.. it's all in the shock
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: BATTERY QUESTION............ [Re: WHITEDART] #2425474
12/29/17 07:14 PM
12/29/17 07:14 PM
State of confusion
State of confusion
Was thinking I could get it done w/the Ranchos as others have but maybe not.......I have to run an alt cos I drive this thing a lot these days testing carbs..........
Re: BATTERY QUESTION............ [Re: Thumperdart] #2425478
12/29/17 07:19 PM
12/29/17 07:19 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
I no only poking at you and honestly your car sounded great Thursday night
Re: BATTERY QUESTION............ [Re: Thumperdart] #2425490
12/29/17 07:34 PM
12/29/17 07:34 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
You can add a second batt with less CCA, or you could just add some ballast high left rear as well. Or you could even go with a smaller Lighter bat and figure your true traction issue out and stop throwing weight at it to fix it. up
Without even seeing a launch of your car, I'm guessing the right rear is lifting abit first causing you to spin loosing your 60 ft time. Just a guess really, may not even be close.
Bottom line, no more bats, figure the traction issue out. up
Re: BATTERY QUESTION............ [Re: Thumperdart] #2425491
12/29/17 07:35 PM
12/29/17 07:35 PM
CA
crackedback Offline
crackedback  Offline
CA
Just add the weight back in if that is the issue.
Shouldn't be an energy issue unless the alternator is not up to snuff.
Re: BATTERY QUESTION............ [Re: Sport440] #2425492
12/29/17 07:36 PM
12/29/17 07:36 PM
State of confusion
State of confusion
This stuff is challenging for sure but WE will get it figured out but we all have also heard of guys adding 50-100 lbs and going WAY quicker and faster........ work Thankxxx Shilo and this new profiled CNC Dommy is a beast cos I hooked before I installed it.......... laugh2
Re: BATTERY QUESTION............ [Re: Thumperdart] #2425510
12/29/17 08:06 PM
12/29/17 08:06 PM
MR_P_BODY Offline
MR_P_BODY  Offline
You just need better shocks.. its not a weight
issue but moving the weight might help you
wave
Re: BATTERY QUESTION............ [Re: Thumperdart] #2425518
12/29/17 08:26 PM
12/29/17 08:26 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Are you saying that the slower 1.40 was also with a different untested carb?
As far as going faster with more weight, of course its because its a band aid suspension fix. Some need to move weight to the Front to fix a power problem vs to the rear because of a suspension problem.
So you got to run your car just recently, great for you, 5* up here.
Re: BATTERY QUESTION............ [Re: Thumperdart] #2425520
12/29/17 08:31 PM
12/29/17 08:31 PM
Carson City, Nevada
Biginchmopar Offline
Carson City, Nevada
What shock are you running White Dart?
Re: BATTERY QUESTION............ [Re: Biginchmopar] #2425525
12/29/17 08:44 PM
12/29/17 08:44 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
Currently I am running the Viking da shock that can be revalved I can't remember if it was the Crusader or the other one. Off the top of my head.. I just came across a set of menscer shocks for the rear.
So the Viking shocks will be coming up in the parts for sale area here in the next week or so
Re: BATTERY QUESTION............ [Re: Thumperdart] #2425533
12/29/17 08:56 PM
12/29/17 08:56 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Well, when we finally get a good run on our first low deck in my car, I will let you know what a good 60ft is...Best with the 440 based was a 1.329 with my pre Thumper carb....
PS we like the red top 900cca battery's. I use just one in each car...But we do use a full size chevy 1-wire alternator.
Also, I spend as much time tuning the front suspension as the rear...This is even more important on a leaf spring car.
Re: BATTERY QUESTION............ [Re: Sport440] #2425550
12/29/17 10:15 PM
12/29/17 10:15 PM
State of confusion
State of confusion
I only got one change on the street on the new carb before the track outing but I don't think it's carb related except for maybe needing bigger squirters than the .032's in it now but not 100% and unlike most, I rarely ever need .035's in anything...........This same thing happened a few years ago........removed 2nd battery, and lost 60 ft just like that and last time out w/2 batts, 1.33 on 3 year old 28x10.5 slicks but they had four inches less circumference compared to the QTP 29X13.5'.........I agree about shocks guys but my dumb azz will just get more confused w/all of the adjust ability........ biggrin
Re: BATTERY QUESTION............ [Re: Thumperdart] #2425564
12/29/17 11:25 PM
12/29/17 11:25 PM
Dragula Offline
Dragula  Offline
No it won't....
Here is the easy way to think of it...I like DA shocks on both ends.
Start loose. Let the front extend, but not return, let the back compress, but not extend....
So on the front start with the loosest extension and tightest compression, and on the back, the opposite....Softest compression, tightest extension.
The only adjustments I tinker with are how fast the front extends and how fast the rear compresses. Usually, the other adjustments at max work. On a fast car, they will end up pretty stiff.
Re: BATTERY QUESTION............ [Re: Dragula] #2425573
12/30/17 12:05 AM
12/30/17 12:05 AM
I don't think I have ever seen a true leaf spring car squat under acceleration, 4 links yes up But not leaf springs even with Cal Tracs or any of the other traction aids for leaf spring cars confused
All the slow speed videos I've seen of leaf spring cars may have the front rise quicker than the back but the back ends rise along with the front, if they spin they won't rise as much normally shruggy
