New wiper motor install #2424642
12/27/17 10:21 PM
12/27/17 10:21 PM
KY USA
mopargem Offline OP
mopargem  Offline OP
KY USA
Hey gang I’m finally installing my 2 spd wiper motor on my 71 Duster project. It’s an NOS motor so I switched levers from my old unit but not sure which way to install, it can go 180 either way with the slotted hole and squared shaft on the motor. Should I reset the motor to park position and after that which direction should the lever point before I attach the linkage? I don’t even know how to reset the park? I did hook 12v to the brown wire and grounded the case to make sure it operated ok but have no idea what position it’s in. I won’t put the blades on until I know all is correct as that would suck if they went wrong way on my new paint if that’s possible. Any help much appreciated!
Re: New wiper motor install [Re: mopargem] #2424653
12/27/17 10:43 PM
12/27/17 10:43 PM
ontario calif
N
ns1aar Offline
ns1aar  Offline
N
ontario calif
The arm should only go on one 1 way. The shaft should have 3 flat sides and 1 rounded side. Also make sure that its the correct motor for an a-body check that it has 4 silver terminals, if it only has 3 it won't work for you. Use this test to make sure it works correctly and to park the motor. Any other questions post here, PM me or email somerbr1@aol.com
My website ns1aar.com
Bruce
Attached PDF document
wipertest.PDF (68 downloads)
NS1AAR
Re: New wiper motor install [Re: ns1aar] #2424657
12/27/17 10:49 PM
12/27/17 10:49 PM
KY USA
mopargem Offline OP
mopargem  Offline OP
KY USA
Thx Bruce yes it has 4 terminals and a resistor identical to my original. Ok I must have gotten lucky on the lever as it went right on and I assumed it could go 180 out. I’ll double check that.
Re: New wiper motor install [Re: mopargem] #2424754
12/28/17 03:01 AM
12/28/17 03:01 AM
ontario calif
N
ns1aar Offline
ns1aar  Offline
N
ontario calif
It should have 4 terminals on the connector but make sure they are all silver
NS1AAR
Re: New wiper motor install [Re: ns1aar] #2425165
12/28/17 11:56 PM
12/28/17 11:56 PM
KY USA
mopargem Offline OP
mopargem  Offline OP
KY USA
Checking my terminals two are silver and two are brass but they also are two and two on the old motor which Im pretty certain is original to the car 71 Duster. Your thoughts Bruce? Thx
68 Polara 500...LL1 Y7 M6X
69 Hemi road runner...X9 X9 M6X
69 A12 road runner....R4 R4 M6X
69 ModTop FLORAL Super Bee...F6 M6W
70 AAR 'cuda...EW1 EW1 H4X9
71 Duster 340...FJ6 V24 L6X9
71 road runner FC7 V1X M6X9
72 Rallye Charger B5 V1W
74 'cuda 360...KB5 V1X A6X9
08 SRT Challenger #234
Re: New wiper motor install [Re: mopargem] #2425243
12/29/17 04:23 AM
12/29/17 04:23 AM
ontario calif
N
ns1aar Offline
ns1aar  Offline
N
ontario calif
never seen that before
try the wiper check for the non revesing motor and see if it works make sure the arms are not installed
NS1AAR
Re: New wiper motor install [Re: ns1aar] #2425598
12/30/17 01:28 AM
12/30/17 01:28 AM
KY USA
mopargem Offline OP
mopargem  Offline OP
KY USA
I did the test and it seems to work fine both speeds. The park test works because it momentarily runs and just stops which I assume is correct for a non reversing style. If you look at the top left of page 12 of the bulletin, it states reversing motor has only one brass but non- reversing had two brass connectors so I do indeed have the corrrct motor. I checked my original old crusty motor and it still works. Maybe I’ll have it refurbished since it’s the original to my car. Here’s a pic of the NOS box the new one came in if you want to see part numbersBought it at least ten years ago off eBay but it’s dated 1977 from the dealer. So I guess next I just hook up my linkage to the crank arm and park the motor and install my blade arms correct? Thx again
