New wiper motor install
#2424642
12/27/17 10:21 PM
12/27/17 10:21 PM
Posts: 3,378 KY USA
mopargem
KY USA
Hey gang I’m finally installing my 2 spd wiper motor on my 71 Duster project. It’s an NOS motor so I switched levers from my old unit but not sure which way to install, it can go 180 either way with the slotted hole and squared shaft on the motor. Should I reset the motor to park position and after that which direction should the lever point before I attach the linkage? I don’t even know how to reset the park? I did hook 12v to the brown wire and grounded the case to make sure it operated ok but have no idea what position it’s in. I won’t put the blades on until I know all is correct as that would suck if they went wrong way on my new paint if that’s possible. Any help much appreciated!
Re: New wiper motor install
[Re: mopargem]
#2424653
12/27/17 10:43 PM
12/27/17 10:43 PM
Posts: 1,145 ontario calif
ns1aar
ontario calif
The arm should only go on one 1 way. The shaft should have 3 flat sides and 1 rounded side. Also make sure that its the correct motor for an a-body check that it has 4 silver terminals, if it only has 3 it won't work for you. Use this test to make sure it works correctly and to park the motor. Any other questions post here, PM me or email somerbr1@aol.com
My website ns1aar.com
Thanks Bruce
NS1AAR
[Re: mopargem]
#2424754
12/28/17 03:01 AM
12/28/17 03:01 AM
ns1aar
ontario calif
It should have 4 terminals on the connector but make sure they are all silver
NS1AAR
[Re: ns1aar]
#2425165
12/28/17 11:56 PM
12/28/17 11:56 PM
Posts: 3,378 KY USA
mopargem
KY USA
Checking my terminals two are silver and two are brass but they also are two and two on the old motor which Im pretty certain is original to the car 71 Duster. Your thoughts Bruce? Thx
68 Polara 500...LL1 Y7 M6X 69 Hemi road runner...X9 X9 M6X 69 A12 road runner....R4 R4 M6X 69 ModTop FLORAL Super Bee...F 70 AAR 'cuda...EW1 EW1 H4X9 71 Duster 340...FJ6 V24 L6X9 71 road runner FC7 V1X M6X9 72 Rallye Charger B5 V1W 74 'cuda 360...KB5 V1X A6X9 08 SRT Challenger #234
[Re: mopargem]
#2425243
12/29/17 04:23 AM
12/29/17 04:23 AM
ns1aar
ontario calif
never seen that before try the wiper check for the non revesing motor and see if it works make sure the arms are not installed
NS1AAR
