Performer deep runner porting #2424744
12/28/17 02:05 AM
12/28/17 02:05 AM
Madison Wi
NTOLERANCE Offline OP
Madison Wi
I need to deep port match the runners on a edelbrock performer 318/360 Intake to match the larger ports on my heads
How deep is deep and what tooling would you recommend ?
Re: Performer deep runner porting [Re: NTOLERANCE] #2424746
12/28/17 02:15 AM
12/28/17 02:15 AM
MR_P_BODY Offline
MR_P_BODY  Offline
You can buy 6" long rotary bits for cutting
alum or steel.. I also have 12" long arbor
when using tooste rolls for porting... all
are used with either a air or electric.. I
use both a lot of times... all 1/4" shanks
wave
Re: Performer deep runner porting [Re: NTOLERANCE] #2424762
12/28/17 03:39 AM
12/28/17 03:39 AM
P
Porter67 Offline
Porter67  Offline
P
$15 a pop on ebay, 6 inch long for die grinder. If you always do al. you will never wear them out. They work good on cast too but will get to a dull point.
They also sell sets with 2 long and 4 short
But one point, one round is all you need. Really either one would do it in a pinch.
Re: Performer deep runner porting [Re: NTOLERANCE] #2424789
12/28/17 07:33 AM
12/28/17 07:33 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
When doing aluminum, be careful about loading up the bits and not cleaning them out with a scribe. I have a 5K rpm air drill that I use for most roughing in with the carbide cutters, I found that the 20K die grinders took off too much material too fast, and they liked to bounce around too much. A little slower = a little more control. The die grinders work good with the sanding rolls though. Tim
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Performer deep runner porting [Re: NTOLERANCE] #2424812
12/28/17 11:52 AM
12/28/17 11:52 AM
an8sec70cuda Offline
Keep dipping the cutter in WD-40 will really help keep the aluminum from building up in the flutes.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Performer deep runner porting [Re: an8sec70cuda] #2424817
12/28/17 12:06 PM
12/28/17 12:06 PM
Awhile back there was a comprehensive thread here on the different types/uses for porting burrs (for faster work/longer life). If my printer was up I wanted to print it out.
Re: Performer deep runner porting [Re: RapidRobert] #2424879
12/28/17 02:14 PM
12/28/17 02:14 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
By the time you buy everything I could have already had it done cheaper and in less time
My shameless get work post for 2017
Re: Performer deep runner porting [Re: NTOLERANCE] #2424892
12/28/17 02:24 PM
12/28/17 02:24 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Have a good port matched gasket to the heads
and make sure the bolt holes line up well.. then
transfer that to the intake.. blend it in as far
as possible
wave
Re: Performer deep runner porting [Re: NTOLERANCE] #2424943
12/28/17 04:02 PM
12/28/17 04:02 PM
All the good aluminum cutters have a lot bigger cutter edges on them and are further a lot further apart than the one shown in that picture. Those type are for steel, iron and other harder metals than aluminum scope
As far as keeping the aluminum from sticking to the bits using candle wax or parafin to coat them frequently helps a lot thumbs I roll the bit in it by hand before starting and again as needed scope
Re: Performer deep runner porting [Re: NTOLERANCE] #2424957
12/28/17 04:30 PM
12/28/17 04:30 PM
P
Porter67 Offline
Porter67  Offline
P
Tell that to the 30 plus manifolds ive worked on and 11 sets of al heads and 8 sets of iron heads.
Just a personal preference that dont dig supper hard and leave a good finish without needing any touch up of any kind. Maybe one time an hour I might have to take 5 seconds on a fine wire brush or hit them with an air hose.
I know your old and wise Cab but there is more then one way to skin a cat.
Re: Performer deep runner porting [Re: Porter67] #2424959
12/28/17 04:40 PM
12/28/17 04:40 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
I rarely use the wider aluminum burrs either. I use a mixture of WD40 and transmission fluid and port at a slower speed than a lot of guys do as I do it for recreation and not money. My Foredom grinder has a foot pedal to control the speed and with using the finer tooth (cast iron burrs) I usually don't even need a sanding roll job after I am finished.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Performer deep runner porting [Re: an8sec70cuda] #2424961
12/28/17 04:47 PM
12/28/17 04:47 PM
Mopar Country, Mi
ccdave Offline
The Ultimate
ccdave  Offline
The Ultimate
Mopar Country, Mi
Yes up
Re: Performer deep runner porting [Re: pittsburghracer] #2424964
12/28/17 04:54 PM
12/28/17 04:54 PM
PA.
"Little"John
"Little"John
PA.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Performer deep runner porting [Re: NTOLERANCE] #2424969
12/28/17 05:00 PM
12/28/17 05:00 PM
pennsylvania
poboyengineering Offline
pennsylvania
John you turned me on to the idea of the $20 router speed control from HF for my electric. works like a champ! Able to control the bounce and the aggressiveness with the speed.
It may be ugly, but it sure is slow.
Girls comb their hair in rear view mirrors and the boys try to look so hard....
Re: Performer deep runner porting [Re: poboyengineering] #2424971
12/28/17 05:06 PM
12/28/17 05:06 PM
PA.
"Little"John
"Little"John
PA.
They work great but if you want to go the next step buy a foot pedal off ebay and really enjoy variable speed.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Performer deep runner porting [Re: NTOLERANCE] #2424975
12/28/17 05:11 PM
12/28/17 05:11 PM
pennsylvania
pennsylvania
I'll look into that once it's warm enough to get back to the shop! Cutter bounce is nothing compared to shivering.
Re: Performer deep runner porting [Re: poboyengineering] #2424982
12/28/17 05:27 PM
12/28/17 05:27 PM
TN
SCATPACK 1 Offline
SCATPACK 1  Offline
TN
LOL Now that is funny.
The shivering gets worse as I get older too.
Old Geezer Racing
Re: Performer deep runner porting [Re: NTOLERANCE] #2424985
12/28/17 05:35 PM
12/28/17 05:35 PM
P
Porter67 Offline
Porter67  Offline
P
Straight low budget here... my $8 pawn shop die grinder and I think my cutters actually came from harbor freight, maybe fifteen years ago, but they work good still.
Re: Performer deep runner porting [Re: SCATPACK 1] #2425017
12/28/17 07:28 PM
12/28/17 07:28 PM
MR_P_BODY Offline
MR_P_BODY  Offline
LOL.. you got that right.. thats why I built a new shop
that has in floor heating.. love it.. I work in a tee shirt
all winter(today started out at -9*)
wave
Re: Performer deep runner porting [Re: NTOLERANCE] #2425052
12/28/17 08:48 PM
12/28/17 08:48 PM
CA
crackedback Offline
crackedback  Offline
CA
