Performer deep runner porting
#2424744
12/28/17 02:05 AM
12/28/17 02:05 AM
Posts: 4,384 Madison Wi
NTOLERANCE
Madison Wi
I need to deep port match the runners on a edelbrock performer 318/360 Intake to match the larger ports on my heads
How deep is deep and what tooling would you recommend ?
Re: Performer deep runner porting
[Re: NTOLERANCE]
#2424746
12/28/17 02:15 AM
12/28/17 02:15 AM
Posts: 52,972 Romeo MI
MR_P_BODY
You can buy 6" long rotary bits for cutting alum or steel.. I also have 12" long arbor when using tooste rolls for porting... all are used with either a air or electric.. I use both a lot of times... all 1/4" shanks
[Re: NTOLERANCE]
#2424789
12/28/17 07:33 AM
12/28/17 07:33 AM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
When doing aluminum, be careful about loading up the bits and not cleaning them out with a scribe. I have a 5K rpm air drill that I use for most roughing in with the carbide cutters, I found that the 20K die grinders took off too much material too fast, and they liked to bounce around too much. A little slower = a little more control. The die grinders work good with the sanding rolls though. Tim
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
[Re: NTOLERANCE]
#2424812
12/28/17 11:52 AM
12/28/17 11:52 AM
Posts: 13,363 Marion, South Carolina [><]
an8sec70cuda
Keep dipping the cutter in WD-40 will really help keep the aluminum from building up in the flutes.
[Re: an8sec70cuda]
#2424817
12/28/17 12:06 PM
12/28/17 12:06 PM
RapidRobert
Awhile back there was a comprehensive thread here on the different types/uses for porting burrs (for faster work/longer life). If my printer was up I wanted to print it out.
[Re: RapidRobert]
#2424879
12/28/17 02:14 PM
12/28/17 02:14 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
By the time you buy everything I could have already had it done cheaper and in less time
My shameless get work post for 2017
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: NTOLERANCE]
#2424892
12/28/17 02:24 PM
12/28/17 02:24 PM
MR_P_BODY
Have a good port matched gasket to the heads and make sure the bolt holes line up well.. then transfer that to the intake.. blend it in as far as possible
[Re: NTOLERANCE]
#2424943
12/28/17 04:02 PM
12/28/17 04:02 PM
Posts: 43,174 Bend,OR USA
Cab_Burge
All the good aluminum cutters have a lot bigger cutter edges on them and are further a lot further apart than the one shown in that picture. Those type are for steel, iron and other harder metals than aluminum As far as keeping the aluminum from sticking to the bits using candle wax or parafin to coat them frequently helps a lot I roll the bit in it by hand before starting and again as needed
[Re: Porter67]
#2424959
12/28/17 04:40 PM
12/28/17 04:40 PM
Posts: 20,174 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I rarely use the wider aluminum burrs either. I use a mixture of WD40 and transmission fluid and port at a slower speed than a lot of guys do as I do it for recreation and not money. My Foredom grinder has a foot pedal to control the speed and with using the finer tooth (cast iron burrs) I usually don't even need a sanding roll job after I am finished.
[Re: NTOLERANCE]
#2424969
12/28/17 05:00 PM
12/28/17 05:00 PM
Posts: 685 pennsylvania
poboyengineering
pennsylvania
John you turned me on to the idea of the $20 router speed control from HF for my electric. works like a champ! Able to control the bounce and the aggressiveness with the speed.
It may be ugly, but it sure is slow.
Girls comb their hair in rear view mirrors and the boys try to look so hard....
[Re: poboyengineering]
#2424971
12/28/17 05:06 PM
12/28/17 05:06 PM
Posts: 20,174 PA.
pittsburghracer
"Little"John
"Little"John
PA.
John you turned me on to the idea of the $20 router speed control from HF for my electric. works like a champ! Able to control the bounce and the aggressiveness with the speed. They work great but if you want to go the next step buy a foot pedal off ebay and really enjoy variable speed.
[Re: NTOLERANCE]
#2424975
12/28/17 05:11 PM
12/28/17 05:11 PM
poboyengineering
pennsylvania
I'll look into that once it's warm enough to get back to the shop! Cutter bounce is nothing compared to shivering.
#2424982
12/28/17 05:27 PM
12/28/17 05:27 PM
Posts: 1,505 TN
SCATPACK 1
TN
I'll look into that once it's warm enough to get back to the shop! Cutter bounce is nothing compared to shivering. LOL Now that is funny. The shivering gets worse as I get older too.
Old Geezer Racing
[Re: SCATPACK 1]
#2425017
12/28/17 07:28 PM
12/28/17 07:28 PM
MR_P_BODY
I'll look into that once it's warm enough to get back to the shop! Cutter bounce is nothing compared to shivering. LOL Now that is funny. The shivering gets worse as I get older too. LOL.. you got that right.. thats why I built a new shop that has in floor heating.. love it.. I work in a tee shirt all winter(today started out at -9*)
[Re: NTOLERANCE]
#2425052
12/28/17 08:48 PM
12/28/17 08:48 PM
Posts: 2,075 CA
crackedback
CA
