Cooling Fan #2423627
12/25/17 04:00 PM
12/25/17 04:00 PM
Az
69hemibeep Offline OP
Az
Is there an after market that will pull more than the factory water pump mounted fixed fan?
1969 Hemi Roadrunner 2nd owner
Re: Cooling Fan [Re: 69hemibeep] #2423648
12/25/17 04:39 PM
12/25/17 04:39 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
Not sure what your combination is, but I've cooled some pretty "hot" motors with stock stuff. Fan shroud is the biggest deal, worth 20 degrees or more. On a couple of cars, using a smaller fan pulley sped up the fan enough to make a significant difference.
I consider 180 in traffic on a 90+ day the max temp I want to see.
OEM fan shrouds for 22" radiators are rare & spendy, but if correct appearance isn't important, later plastic shrouds can be adapted. Also, Speedway in Lincoln, NE sells a universal shroud that fits a 26" rad pretty well but you have to fab brackets.
Re: Cooling Fan [Re: 69hemibeep] #2423667
12/25/17 05:33 PM
12/25/17 05:33 PM
More info on what is going on, what pump (# of vanes/anti cav plate or not) how many fan blades. what stat. spring in lower hose? Stat opening all the way. shroud or no shroud. timing/A/F ratio in the ballpark. running hot at idle or around town or on highway. how hot. confirmed with an accurate gauge. any recent part/adjustment settings that could be impacting the cooling system (or A/F ratio). recent issue. happened out of the clear blue.
Re: Cooling Fan [Re: 69hemibeep] #2423672
12/25/17 05:41 PM
12/25/17 05:41 PM
Az
Az
Summer time here of coarse its going to run warm but manageable but when I added the A/C condenser it was to much without the air turned on, the main problem is at traffic stops. 68 Valiant 440 auto 18" 6 blade fan shroud 3" thick 22" Champion radiator Mopar performance aluminum water pump and housing 180 stat
Re: Cooling Fan [Re: 69hemibeep] #2423676
12/25/17 05:54 PM
12/25/17 05:54 PM
Yes as you surmised you need more airflow. I'm thinking 6 blades is adequate & that the pulley ratio needs speeded up & the fan does need to be properly spaced into the shroud (~1/2 or a bit more in). its tough to get the right pulley with the right depth so the belts line up.
Re: Cooling Fan [Re: 69hemibeep] #2423715
12/25/17 08:24 PM
12/25/17 08:24 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Clutch or no clutch fan?
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Cooling Fan [Re: 69hemibeep] #2423738
12/25/17 09:49 PM
12/25/17 09:49 PM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
I was looking for the same answer a little while back
https://board.moparts.org/ubbthreads/ubbt...tml#Post2416262
Facts are stubborn things.
Re: Cooling Fan [Re: 69hemibeep] #2423846
12/26/17 10:38 AM
12/26/17 10:38 AM
Az
Az
No clutch, no room. I do have the spring in the lower hose but that is for cruising speeds. Read my plugs and they show a lean condition which equals heat and I'm thinking a header wrap to get some of the heat out from under hood.
Re: Cooling Fan [Re: 69hemibeep] #2423852
12/26/17 11:18 AM
12/26/17 11:18 AM
Northern OH
rapom Offline
rapom  Offline
Northern OH
I had a problem like yours only my a/c wouldn't work well when sitting in traffic. I have a fixed fan with a shroud. I installed a pusher electric fan on top of the condensor and the problem was fixed. It only comes on when the a/c is on or if I get above 180.
Re: Cooling Fan [Re: 69hemibeep] #2424135
12/26/17 10:35 PM
12/26/17 10:35 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
I much prefer the Milodon Water Pump with anti-cav plate to the MP pump, as much as I like to keep things Mopar whenever possible
