Cooling Fan
#2423627
12/25/17 04:00 PM
12/25/17 04:00 PM
Posts: 1,385 Az
69hemibeep
Az
Is there an after market that will pull more than the factory water pump mounted fixed fan?
1969 Hemi Roadrunner 2nd owner
Re: Cooling Fan
[Re: 69hemibeep]
#2423667
12/25/17 05:33 PM
12/25/17 05:33 PM
RapidRobert
More info on what is going on, what pump (# of vanes/anti cav plate or not) how many fan blades. what stat. spring in lower hose? Stat opening all the way. shroud or no shroud. timing/A/F ratio in the ballpark. running hot at idle or around town or on highway. how hot. confirmed with an accurate gauge. any recent part/adjustment settings that could be impacting the cooling system (or A/F ratio). recent issue. happened out of the clear blue.
Re: Cooling Fan
[Re: 69hemibeep]
#2423672
12/25/17 05:41 PM
12/25/17 05:41 PM
Posts: 1,385 Az
69hemibeep
Az
Summer time here of coarse its going to run warm but manageable but when I added the A/C condenser it was to much without the air turned on, the main problem is at traffic stops. 68 Valiant 440 auto 18" 6 blade fan shroud 3" thick 22" Champion radiator Mopar performance aluminum water pump and housing 180 stat
Re: Cooling Fan
[Re: 69hemibeep]
#2423676
12/25/17 05:54 PM
12/25/17 05:54 PM
RapidRobert
but when I added the A/C condenser it was to much without the air turned on, the main problem is at traffic stops. Yes as you surmised you need more airflow. I'm thinking 6 blades is adequate & that the pulley ratio needs speeded up & the fan does need to be properly spaced into the shroud (~1/2 or a bit more in). its tough to get the right pulley with the right depth so the belts line up.
Re: Cooling Fan
[Re: 69hemibeep]
#2423846
12/26/17 10:38 AM
12/26/17 10:38 AM
Posts: 1,385 Az
69hemibeep
Az
No clutch, no room. I do have the spring in the lower hose but that is for cruising speeds. Read my plugs and they show a lean condition which equals heat and I'm thinking a header wrap to get some of the heat out from under hood.
Re: Cooling Fan
[Re: 69hemibeep]
#2424135
12/26/17 10:35 PM
12/26/17 10:35 PM
Posts: 15,894 Central Florida
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
I much prefer the Milodon Water Pump with anti-cav plate to the MP pump, as much as I like to keep things Mopar whenever possible
Facts are stubborn things.
