Re: I hope this can be fixed but probably not:
[Re: hudsonhornet7x]
#2419545
12/16/17 06:02 PM
12/16/17 06:02 PM
Posts: 1,400 Trumbauersville PA
ric3xrt
Trumbauersville PA
What's the build? That spot that you have circled , only has coolant pressure to deal with .I my self am crazy enough to JB weld the broken piece re tap it and roll the dice.....If it were an engine I was building for someone else, I wouldn't take the chance.
Truth has no agenda, but those with an agenda make their own truth. Some of us are so open minded they only see their View
[Re: ric3xrt]
#2419653
12/16/17 11:24 PM
12/16/17 11:24 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
I have cast iron plates for my press. Someone was using my press and broke one!!! I mig welded it. Its been holding up fine but I think a machine shop can fix it
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: ric3xrt]
#2419679
12/17/17 12:38 AM
12/17/17 12:38 AM
Posts: 25,050 Texas
GoodysGotaCuda
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
What's the build? That spot that you have circled , only has coolant pressure to deal with .I my self am crazy enough to JB weld the broken piece re tap it and roll the dice.....If it were an engine I was building for someone else, I wouldn't take the chance. Agreed, I'd try to make something work there. Just make sure it's flat without messing up any other sealing surfaces. The M8[?] bolt torque there is fairly low.
[Re: ric3xrt]
#2420611
12/18/17 09:18 PM
12/18/17 09:18 PM
ric3xrt
Trumbauersville PA
What's the build? That spot that you have circled , only has coolant pressure to deal with .I my self am crazy enough to JB weld the broken piece re tap it and roll the dice.....If it were an engine I was building for someone else, I wouldn't take the chance, I would have it brazed I edited this because I thought I finished my thought,
#2450784
02/12/18 06:14 PM
02/12/18 06:14 PM
Posts: 543 Indiana, Just Off I-70
BradD
We have a Silicon Bronze mig welder in the body shop. I believe that would work after V-ing out the sides. may try that first at a local collision shop.
Brad
Check out the Dorn's 69 Barracuda "Switchblade" in the Nov.2010 MCG Check out the Dorn's refurbished 36 Ford in the Feb.2011 Street Rodder
[Re: Dragula]
#2450993
02/12/18 11:35 PM
02/12/18 11:35 PM
Posts: 1,542 USA
hudsonhornet7x
USA
You are 3 hours from our shop here near Lockport NY and 2 hours or less away from Bob George Racing in Eighty Four Pa...Yes, it can be fixed, good as new. Don't loose the piece that broke off. I still have the piece. Any Idea of cost to fix? Curious is all.
#2451040
02/13/18 12:52 AM
02/13/18 12:52 AM
Posts: 12,394 Taxes & Virus's R-US, NY
Dragula
You are 3 hours from our shop here near Lockport NY and 2 hours or less away from Bob George Racing in Eighty Four Pa...Yes, it can be fixed, good as new. Don't loose the piece that broke off. I still have the piece. Any Idea of cost to fix? Curious is all. Maybe $200 or a little less...Its more labor to get the block up to temp...
