8.75 to Dana 60 swap #2418645
12/14/17 08:19 PM
12/14/17 08:19 PM
lancaster,california
johnnycuda Offline OP
Hey guys, thinking of ordering a Strange S60 to replace the 8.75 rear in my '70 Cuda. Are the factory units the same width, drum face to drum face?, my springs are moved inboard, so I know I'll have to handle that, just want to make sure my wheel/tire combo still fits or doesn't sit too far in with the Dana if I order it stock length.
I know driveshaft length is different etc,
Thanks!
1970 'Cuda,Lime Light,499 Indy S/R's 10.70's @125,street driven ALOT!
1966 Barracuda 360,now a 5spd,Hemi Orange,Hot Rod Air,
New daily driver-2003 Ram 2500 Cummins 5.9
'69 Valiant 2-dr, sleeper!
New project---1938 Dodge truck, plan is a 360 with a A500, AC, Calvert rear susp., rack and pinion front with coils.
Re: 8.75 to Dana 60 swap [Re: johnnycuda] #2418648
12/14/17 08:24 PM
12/14/17 08:24 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Why don't you just tell them what length you want ?!?
Re: 8.75 to Dana 60 swap [Re: johnnycuda] #2418651
12/14/17 08:30 PM
12/14/17 08:30 PM
I haven't measured it as of yet as its in storage at the moment, thought if the two were the same length from the factory, could just them tell them stock length. They are closed at the moment, so thought I would ask guys here, maybe someone went thru this.
Re: 8.75 to Dana 60 swap [Re: johnnycuda] #2418660
12/14/17 08:52 PM
12/14/17 08:52 PM
CA
crackedback Offline
crackedback  Offline
CA
8.75 and Dana 60 are the same in stock configurations.
Re: 8.75 to Dana 60 swap [Re: johnnycuda] #2418665
12/14/17 08:57 PM
12/14/17 08:57 PM
Thanks, thats what I figured, wanted to check, probably order on Monday, just have to make decision on ratio,
Thanks again!
Re: 8.75 to Dana 60 swap [Re: johnnycuda] #2418677
12/14/17 09:14 PM
12/14/17 09:14 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
A friend tried to order the S60 from Strange to replace the stock 8-3/4 in his Duster. They wanted him to measure everything (fill out the spec sheet) he said it was stock, uncut, even springs not moved, still a hassle. Called Moser, they said no problem, they know what size it is, sent out in two days, completely set up ready to go. He told them 5.12 gear, 5/8 studs, spool and 1350 yoke.
Re: 8.75 to Dana 60 swap [Re: cudaman1969] #2418702
12/14/17 09:49 PM
12/14/17 09:49 PM
Locomotion Offline
Locomotion  Offline
X2 on Moser.
I just put an order in to Moser, but mine will take a bit longer because the ring & pinion will be lightened and micro-finished. Not in a real big hurry, especially considering the holidays.
If you're sure the rear is OEM width, it shouldn't be a problem. Just specify that you'd like the spring pads shipped loose.
Moser 60 built to order.
Re: 8.75 to Dana 60 swap [Re: johnnycuda] #2418707
12/14/17 09:53 PM
12/14/17 09:53 PM
Northern OH
rapom Offline
rapom  Offline
Northern OH
Is the driveshaft shorter or longer for the Dana 60
Re: 8.75 to Dana 60 swap [Re: rapom] #2418722
12/14/17 10:29 PM
12/14/17 10:29 PM
Locomotion Offline
Locomotion  Offline
Shorter by approximately 1", if I remember correctly. But it's best to check everything in place.
Re: 8.75 to Dana 60 swap [Re: johnnycuda] #2418732
12/14/17 10:48 PM
12/14/17 10:48 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
Contact Dr Diff
Re: 8.75 to Dana 60 swap [Re: johnnycuda] #2418747
12/14/17 11:23 PM
12/14/17 11:23 PM
georgia
intenseneon Offline
intenseneon  Offline
georgia
If you go with a strange60 and your springs are moved in make sure to tell them how many inches for each side.
69 Dart
Re: 8.75 to Dana 60 swap [Re: johnnycuda] #2418796
12/15/17 12:51 AM
12/15/17 12:51 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
curious... does the Moser 60 have side adjusters like the Strange S60? That alone was worth the price of admission in my book.
I agree on calling Cass (Dr.Diff). http://www.doctordiff.com/
....AND, I would seriously consider just going a 9" since you are upgrading across the board.
Re: 8.75 to Dana 60 swap [Re: johnnycuda] #2418858
12/15/17 03:08 AM
12/15/17 03:08 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Ordering a Mopar spec Strange-60/Dana-60 is easy on my web-site:
http://www.doctordiff.com/strange-60.html
Stock/custom dimensions for popular rearends are easy to determine using my calculator:
http://www.doctordiff.com/axle-calculator/
Re: 8.75 to Dana 60 swap [Re: johnnycuda] #2418936
12/15/17 12:27 PM
12/15/17 12:27 PM
an8sec70cuda Offline
Moser 60s don't have the side adjusters.
My Moser 60 was the correct E body width as ordered back in 2003. Don't think Strange was even making one back then. I like the side adjusters on the Strange case, but that's the only good thing about Strange's products IMO.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: 8.75 to Dana 60 swap [Re: an8sec70cuda] #2418985
12/15/17 02:01 PM
12/15/17 02:01 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Moser made my friend a S60 with the side adjusters, summer before last.
Re: 8.75 to Dana 60 swap [Re: johnnycuda] #2420269
12/18/17 12:01 PM
12/18/17 12:01 PM
Moser made a S60? So Moser built a rear from a Strange case? Or are you saying that Moser's case now has side adjusters? They didn't use to, mine doesn't...but mine was bought back in 2003 or 2004, so things may have changed w/o my knowledge.
CHIP
Re: 8.75 to Dana 60 swap [Re: johnnycuda] #2420441
12/18/17 05:36 PM
12/18/17 05:36 PM
New York
polyspheric Offline
polyspheric  Offline
New York
WRT chassis settings: AFAIK the 60 still weighs more than the 8.75, which means slightly more spring and shock to control it. Try it as-is first, you may be lucky.
There may also be a difference between the two as to exactly where the shock mounts: horizontal or vertical distance from the lower eye to the axle center. This affects how much leverage the shock has on axle rotation.
Boffin Emeritus
Re: 8.75 to Dana 60 swap [Re: an8sec70cuda] #2420568
12/18/17 08:17 PM
12/18/17 08:17 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Moser can buy the S60s too, then resale, Strange don't care who buys them.
Re: 8.75 to Dana 60 swap [Re: cudaman1969] #2420870
12/19/17 11:45 AM
12/19/17 11:45 AM
OK, that's what I was wondering b/c the M60 doesn't have side adjusters. up
CHIP
