8.75 to Dana 60 swap
#2418645
12/14/17 08:19 PM
12/14/17 08:19 PM
Posts: 860 lancaster,california
johnnycuda
Hey guys, thinking of ordering a Strange S60 to replace the 8.75 rear in my '70 Cuda. Are the factory units the same width, drum face to drum face?, my springs are moved inboard, so I know I'll have to handle that, just want to make sure my wheel/tire combo still fits or doesn't sit too far in with the Dana if I order it stock length. I know driveshaft length is different etc,
Thanks!
1970 'Cuda,Lime Light,499 Indy S/R's 10.70's @125,street driven ALOT! 1966 Barracuda 360,now a 5spd,Hemi Orange,Hot Rod Air, New daily driver-2003 Ram 2500 Cummins 5.9 '69 Valiant 2-dr, sleeper! New project---1938 Dodge truck, plan is a 360 with a A500, AC, Calvert rear susp., rack and pinion front with coils.
Re: 8.75 to Dana 60 swap
[Re: johnnycuda]
#2418651
12/14/17 08:30 PM
12/14/17 08:30 PM
johnnycuda
I haven't measured it as of yet as its in storage at the moment, thought if the two were the same length from the factory, could just them tell them stock length. They are closed at the moment, so thought I would ask guys here, maybe someone went thru this.
[Re: johnnycuda]
#2418665
12/14/17 08:57 PM
12/14/17 08:57 PM
johnnycuda
Thanks, thats what I figured, wanted to check, probably order on Monday, just have to make decision on ratio, Thanks again!
[Re: johnnycuda]
#2418677
12/14/17 09:14 PM
12/14/17 09:14 PM
Posts: 8,257 fredericksburg,va
cudaman1969
fredericksburg,va
A friend tried to order the S60 from Strange to replace the stock 8-3/4 in his Duster. They wanted him to measure everything (fill out the spec sheet) he said it was stock, uncut, even springs not moved, still a hassle. Called Moser, they said no problem, they know what size it is, sent out in two days, completely set up ready to go. He told them 5.12 gear, 5/8 studs, spool and 1350 yoke.
[Re: cudaman1969]
#2418702
12/14/17 09:49 PM
12/14/17 09:49 PM
Posts: 5,894 Florida
Locomotion
X2 on Moser. I just put an order in to Moser, but mine will take a bit longer because the ring & pinion will be lightened and micro-finished. Not in a real big hurry, especially considering the holidays. If you're sure the rear is OEM width, it shouldn't be a problem. Just specify that you'd like the spring pads shipped loose. Moser 60 built to order.
[Re: johnnycuda]
#2418707
12/14/17 09:53 PM
12/14/17 09:53 PM
Posts: 1,883 Northern OH
rapom
Northern OH
Is the driveshaft shorter or longer for the Dana 60
[Re: johnnycuda]
#2418747
12/14/17 11:23 PM
12/14/17 11:23 PM
Posts: 76 georgia
intenseneon
georgia
If you go with a strange60 and your springs are moved in make sure to tell them how many inches for each side.
69 Dart
[Re: johnnycuda]
#2418796
12/15/17 12:51 AM
12/15/17 12:51 AM
Posts: 13,189 aZLiViN
J_BODY
aZLiViN
curious... does the Moser 60 have side adjusters like the Strange S60? That alone was worth the price of admission in my book. I agree on calling Cass (Dr.Diff). http://www.doctordiff.com/....AND, I would seriously consider just going a 9" since you are upgrading across the board.
[Re: johnnycuda]
#2418936
12/15/17 12:27 PM
12/15/17 12:27 PM
Posts: 13,363 Marion, South Carolina [><]
an8sec70cuda
Moser 60s don't have the side adjusters. My Moser 60 was the correct E body width as ordered back in 2003. Don't think Strange was even making one back then. I like the side adjusters on the Strange case, but that's the only good thing about Strange's products IMO.
[Re: an8sec70cuda]
#2418985
12/15/17 02:01 PM
12/15/17 02:01 PM
cudaman1969
fredericksburg,va
Moser 60s don't have the side adjusters. My Moser 60 was the correct E body width as ordered back in 2003. Don't think Strange was even making one back then. I like the side adjusters on the Strange case, but that's the only good thing about Strange's products IMO. Moser made my friend a S60 with the side adjusters, summer before last.
[Re: johnnycuda]
#2420269
12/18/17 12:01 PM
12/18/17 12:01 PM
an8sec70cuda
Moser made a S60? So Moser built a rear from a Strange case? Or are you saying that Moser's case now has side adjusters? They didn't use to, mine doesn't...but mine was bought back in 2003 or 2004, so things may have changed w/o my knowledge.
[Re: johnnycuda]
#2420441
12/18/17 05:36 PM
12/18/17 05:36 PM
Posts: 4,206 New York
polyspheric
New York
WRT chassis settings: AFAIK the 60 still weighs more than the 8.75, which means slightly more spring and shock to control it. Try it as-is first, you may be lucky. There may also be a difference between the two as to exactly where the shock mounts: horizontal or vertical distance from the lower eye to the axle center. This affects how much leverage the shock has on axle rotation.
Boffin Emeritus
[Re: an8sec70cuda]
#2420568
12/18/17 08:17 PM
12/18/17 08:17 PM
cudaman1969
fredericksburg,va
Moser made a S60? So Moser built a rear from a Strange case? Or are you saying that Moser's case now has side adjusters? They didn't use to, mine doesn't...but mine was bought back in 2003 or 2004, so things may have changed w/o my knowledge. Moser can buy the S60s too, then resale, Strange don't care who buys them.
[Re: cudaman1969]
#2420870
12/19/17 11:45 AM
12/19/17 11:45 AM
an8sec70cuda
Moser made a S60? So Moser built a rear from a Strange case? Or are you saying that Moser's case now has side adjusters? They didn't use to, mine doesn't...but mine was bought back in 2003 or 2004, so things may have changed w/o my knowledge. Moser can buy the S60s too, then resale, Strange don't care who buys them. OK, that's what I was wondering b/c the M60 doesn't have side adjusters.
