Has anyone welded their K frame to sub frame? #2409034
11/26/17 10:50 AM
11/26/17 10:50 AM
Tacoma, Washington USA
Adam71Charger Offline OP
I have rebuilt my front suspension, boxed my LCA's, reinforced my K frame and steering box mount, welded hefty subframe connectors in.. and the thought started rolling around my head, weld the k frame to the sub frame? Has anyone done this? It's just a thought that flashed in my brain that has no experience or research to back it up, so i thought I'd ask here, would it have any benefit like improved rigidity?
Re: Has anyone welded their K frame to sub frame? [Re: Adam71Charger] #2409051
11/26/17 11:57 AM
11/26/17 11:57 AM
K
KOS Offline
KOS  Offline
K
I pretty sure Hemi Fred did that in his duster.....I think I still may have pix.try a search using his name you'll probably find it.
Re: Has anyone welded their K frame to sub frame? [Re: Adam71Charger] #2409089
11/26/17 01:32 PM
11/26/17 01:32 PM
New York
polyspheric Offline
polyspheric  Offline
New York
IMHO the attachment points, and the frame and K strength at these points, is very good - which means it won't be better welded.
But it will be a service headache.
Could a lighter K be designed that required welding? Could be.
Boffin Emeritus
Re: Has anyone welded their K frame to sub frame? [Re: Adam71Charger] #2409118
11/26/17 02:28 PM
11/26/17 02:28 PM
AndyF Offline
AndyF  Offline
Sure, 40 years ago that is how the NASCAR boys built their cars. They moved the K frame up into the frame rails and welded it all together.
Re: Has anyone welded their K frame to sub frame? [Re: Adam71Charger] #2409159
11/26/17 04:17 PM
11/26/17 04:17 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
I have seen it done, along with moving attachment points in the frame rail to cheat the wheelbase forward, and other tricks. I don't believe there would be an advantage strength wise and I wouldn't paint myself into a corner by doing it myself.
Re: Has anyone welded their K frame to sub frame? [Re: Adam71Charger] #2409164
11/26/17 04:27 PM
11/26/17 04:27 PM
MR_P_BODY Offline
MR_P_BODY  Offline
If you have rubber idolators in there now
just put in alum mounts to make it stiff..
dont weld it up... just a PITA.. if you are
steel now you wont gain anything.. just make
sure the bolts are tight so it doesnt move
around
wave
Re: Has anyone welded their K frame to sub frame? [Re: MR_P_BODY] #2409169
11/26/17 04:41 PM
11/26/17 04:41 PM
fullmetaljacket Offline
I don't think there was any benefit in mine, but I Tig welded the K to the frame longitudes and have titanium bolts holding in place of the stock ones to the frame. Very stiff I must say, but if I ever had to service it as in replacing the K, I would have to cut away the tig beads with a Dremel in order for it to detach.
Re: Has anyone welded their K frame to sub frame? [Re: Adam71Charger] #2409173
11/26/17 04:46 PM
11/26/17 04:46 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
What year car? If it is a 71, or older it already has special shoulder bolts in it.
