Has anyone welded their K frame to sub frame?
#2409034
11/26/17 10:50 AM
11/26/17 10:50 AM
Posts: 1,521 Tacoma, Washington USA
Adam71Charger
I have rebuilt my front suspension, boxed my LCA's, reinforced my K frame and steering box mount, welded hefty subframe connectors in.. and the thought started rolling around my head, weld the k frame to the sub frame? Has anyone done this? It's just a thought that flashed in my brain that has no experience or research to back it up, so i thought I'd ask here, would it have any benefit like improved rigidity?
Re: Has anyone welded their K frame to sub frame?
[Re: Adam71Charger]
#2409089
11/26/17 01:32 PM
11/26/17 01:32 PM
Posts: 4,209 New York
polyspheric
New York
IMHO the attachment points, and the frame and K strength at these points, is very good - which means it won't be better welded. But it will be a service headache. Could a lighter K be designed that required welding? Could be.
Boffin Emeritus
[Re: Adam71Charger]
#2409159
11/26/17 04:17 PM
11/26/17 04:17 PM
Posts: 11,608 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
I have seen it done, along with moving attachment points in the frame rail to cheat the wheelbase forward, and other tricks. I don't believe there would be an advantage strength wise and I wouldn't paint myself into a corner by doing it myself.
[Re: Adam71Charger]
#2409164
11/26/17 04:27 PM
11/26/17 04:27 PM
Posts: 52,972 Romeo MI
MR_P_BODY
If you have rubber idolators in there now just put in alum mounts to make it stiff.. dont weld it up... just a PITA.. if you are steel now you wont gain anything.. just make sure the bolts are tight so it doesnt move around
