30" tyre in a 68 b body #2392205
10/24/17 08:49 AM
10/24/17 08:49 AM
Sydney,Australia
tex013 Offline OP
tex013  Offline OP
Sydney,Australia
I have a 68 Satellite , stock width dana , stock spring location . Currently have a 15x10 wheel and 28x10.5 R15 pro bracket radial . I tried a 29.5x10.5 PBR (29.9 tall ) on a 8.5 wide wheel today and tyre is pretty well touching the dog leg .
What are people doing to fit a taller tyre ?
1/4" spacer at front spring mount won't cut it as is . Will a 10" rim drop diameter enough to get by with a spacer ?
Fit the dodge b body front spring hanger and go to 117 wheelbase ?
I have tried the 295/65 et street ss (30.3 tall ) on a 10" rim , it hit the dogleg when i shut throttle after finish line stripe
Thoughts ?
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: 30" tyre in a 68 b body [Re: tex013] #2392261
10/24/17 11:54 AM
10/24/17 11:54 AM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
I moved my axle back 1" with a spacer in front of the spring mount in front but this was a 69 and to stop rubbing on the front of the wheel opening.Yes you need a longer drive shaft then.
Re: 30" tyre in a 68 b body [Re: tex013] #2392347
10/24/17 02:35 PM
10/24/17 02:35 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Thats a bummer as the 30 x 9 Hoosier I run fits my 63 with room to spare. I can actually fit a 31" tire in my stock wheelwell. I guess all you can do is move the rear back or trim the front of the wheelwell. When I had my 66 Dart it had a mld on the rear wheelwells that was about 2" thick near the bottom and it worked nice as I removed it and trimmed an inch of the wheelwell and then reinstalled the mld and all looked normal. Ron
Re: 30" tyre in a 68 b body [Re: tex013] #2392366
10/24/17 03:02 PM
10/24/17 03:02 PM
Cab_Burge Online work
Cab_Burge  Online Work
We have always trimmed the front edge of the wheel wells to fit taller tires shruggy hammer scope
Re: 30" tyre in a 68 b body [Re: tex013] #2392471
10/24/17 06:34 PM
10/24/17 06:34 PM
Sydney,Australia
tex013 Offline OP
tex013  Offline OP
Sydney,Australia
thanks guys . funny I tried a 9x30 (29.9) hoosier radial and it fitted , did this a couple of years ago - I think on the 8 1/2"rim . Maybe the narrower tyre was the saving grace .
Oh well , I guess either a spacer or I will go the dodge hanger .
Clanton , 68-69 should be same as , thanks
Tex
New best MPH 130.32
Re: 30" tyre in a 68 b body [Re: tex013] #2392492
10/24/17 07:24 PM
10/24/17 07:24 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
On the B-body Plymouths there isn't much to trim before you hit the tub - may 3/4" at most.
I didn't take this photo for this purpose but you can see there isn't much room to trim
Re: 30" tyre in a 68 b body [Re: tex013] #2392501
10/24/17 07:40 PM
10/24/17 07:40 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
Tex
my tire was a 29.5x10.5 15" rim 5 on 5 offset but that would be too close for most of you so the 9" will be fine[just touched].I used a 9x30 without the axle moved back at 7k rpm 150 mph on the dyno 3.73 gear.The 9" barely touched so a 1/2" spacer would be fine on the leaf spring.
Re: 30" tyre in a 68 b body [Re: Clanton] #2392716
10/25/17 01:32 AM
10/25/17 01:32 AM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
If it was me I'd a) check all of the other front spring hangers and see if one of them will work (i.e. Dodge ,Plymouth, superstock and non-SS).
Plan b) would be to buy the 2" longer SS front hangers and drill them for 1"and trim excess. I have a 29.5x10.50 in my '66 Charger and other than the above my only tricks are to use a 68-69 width Dana and replace the rear shackles with sliders.
AR Engineering makes really nice front spring hangers if you didn't know about them. I bought several sets from FirmFeel during mock up.
Re: 30" tyre in a 68 b body [Re: Jeremiah] #2392720
10/25/17 01:40 AM
10/25/17 01:40 AM
Sydney,Australia
tex013 Offline OP
tex013  Offline OP
Sydney,Australia
thanks Jeremiah .
Here in Oz not so easy to buy and try multiple hangers . I have to import them , I will probably check measurement on my mate's Charger and go from there . I don't really like the idea of more than 1/4"spacer
Tex
New best MPH 130.32
Re: 30" tyre in a 68 b body [Re: tex013] #2392726
10/25/17 02:06 AM
10/25/17 02:06 AM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
Measure yours and I'll let you know how the three sets I have measure against them. Let me wallet work for both of us : )
Re: 30" tyre in a 68 b body [Re: tex013] #2392765
10/25/17 06:08 AM
10/25/17 06:08 AM
Sydney,Australia
tex013 Offline OP
tex013  Offline OP
Sydney,Australia
Thanks man
Will climb under car tomorrow at work
A mate measured his charger and coronet, 3 1/2" mount face to centre ov bolt
Tex
New best MPH 130.32
Re: 30" tyre in a 68 b body [Re: tex013] #2392839
10/25/17 11:59 AM
10/25/17 11:59 AM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
This is mine,I have had it this way for more than 10 yrs,6061 T6.if you are worried about cracking the mount you need to spread the load with a plate on the back side.
Re: 30" tyre in a 68 b body [Re: Jeremiah] #2393069
10/25/17 08:54 PM
10/25/17 08:54 PM
Sydney,Australia
tex013 Offline OP
tex013  Offline OP
Sydney,Australia
Jeremiah ,
the hangers on my Plymouth are 2 1/2" face to centre of bolt .
let me know
thanks ,
Tex
New best MPH 130.32
Re: 30" tyre in a 68 b body [Re: tex013] #2393239
10/26/17 05:31 AM
10/26/17 05:31 AM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
I will check my stash in the morning. It sound like a Dodge bracket at 3.5" would dothe trick?
Re: 30" tyre in a 68 b body [Re: Jeremiah] #2393241
10/26/17 06:45 AM
10/26/17 06:45 AM
Sydney,Australia
tex013 Offline OP
tex013  Offline OP
Sydney,Australia
May be easiest . Or bigger spacer like Clanton . 2 more race meetings this year , national event then final round track championship in next 4 weeks . Then i will get stuck into this and check rear of tyre clearance .
Tex
New best MPH 130.32
