30" tyre in a 68 b body
#2392205
10/24/17 08:49 AM
10/24/17 08:49 AM
Posts: 2,457 Sydney,Australia
tex013
Sydney,Australia
I have a 68 Satellite , stock width dana , stock spring location . Currently have a 15x10 wheel and 28x10.5 R15 pro bracket radial . I tried a 29.5x10.5 PBR (29.9 tall ) on a 8.5 wide wheel today and tyre is pretty well touching the dog leg . What are people doing to fit a taller tyre ? 1/4" spacer at front spring mount won't cut it as is . Will a 10" rim drop diameter enough to get by with a spacer ? Fit the dodge b body front spring hanger and go to 117 wheelbase ? I have tried the 295/65 et street ss (30.3 tall ) on a 10" rim , it hit the dogleg when i shut throttle after finish line stripe
Thoughts ?
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
Re: 30" tyre in a 68 b body
[Re: tex013]
#2392471
10/24/17 06:34 PM
10/24/17 06:34 PM
tex013
Sydney,Australia
thanks guys . funny I tried a 9x30 (29.9) hoosier radial and it fitted , did this a couple of years ago - I think on the 8 1/2"rim . Maybe the narrower tyre was the saving grace . Oh well , I guess either a spacer or I will go the dodge hanger . Clanton , 68-69 should be same as , thanks
Tex
[Re: tex013]
#2392492
10/24/17 07:24 PM
10/24/17 07:24 PM
Posts: 8,828 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
We have always trimmed the front edge of the wheel wells to fit taller tires On the B-body Plymouths there isn't much to trim before you hit the tub - may 3/4" at most. I didn't take this photo for this purpose but you can see there isn't much room to trim
[Re: tex013]
#2392501
10/24/17 07:40 PM
10/24/17 07:40 PM
Posts: 4,488 northern,Ohio,USA
Clanton
northern,Ohio,USA
Tex my tire was a 29.5x10.5 15" rim 5 on 5 offset but that would be too close for most of you so the 9" will be fine[just touched].I used a 9x30 without the axle moved back at 7k rpm 150 mph on the dyno 3.73 gear.The 9" barely touched so a 1/2" spacer would be fine on the leaf spring.
[Re: Jeremiah]
#2392720
10/25/17 01:40 AM
10/25/17 01:40 AM
tex013
Sydney,Australia
If it was me I'd a) check all of the other front spring hangers and see if one of them will work (i.e. Dodge ,Plymouth, superstock and non-SS).
Plan b) would be to buy the 2" longer SS front hangers and drill them for 1"and trim excess. I have a 29.5x10.50 in my '66 Charger and other than the above my only tricks are to use a 68-69 width Dana and replace the rear shackles with sliders.
AR Engineering makes really nice front spring hangers if you didn't know about them. I bought several sets from FirmFeel during mock up. thanks Jeremiah . Here in Oz not so easy to buy and try multiple hangers . I have to import them , I will probably check measurement on my mate's Charger and go from there . I don't really like the idea of more than 1/4"spacer Tex
[Re: tex013]
#2392765
10/25/17 06:08 AM
10/25/17 06:08 AM
tex013
Sydney,Australia
Thanks man Will climb under car tomorrow at work A mate measured his charger and coronet, 3 1/2" mount face to centre ov bolt
Tex
[Re: Jeremiah]
#2393069
10/25/17 08:54 PM
10/25/17 08:54 PM
tex013
Sydney,Australia
Measure yours and I'll let you know how the three sets I have measure against them. Let me wallet work for both of us : ) Jeremiah , the hangers on my Plymouth are 2 1/2" face to centre of bolt . let me know thanks , Tex
[Re: Jeremiah]
#2393241
10/26/17 06:45 AM
10/26/17 06:45 AM
tex013
Sydney,Australia
I will check my stash in the morning. It sound like a Dodge bracket at 3.5" would dothe trick? May be easiest . Or bigger spacer like Clanton . 2 more race meetings this year , national event then final round track championship in next 4 weeks . Then i will get stuck into this and check rear of tyre clearance . Tex
