California-Built 1970 Coronet R/T Fuel Issues: HELP! #2377872
09/27/17 06:55 PM
09/27/17 06:55 PM
Jackson, Mississippi
CornDogsCharger Offline OP
Hey guys, I've been searching and haven't really found an answer to this. We've got a 1970 Dodge Coronet R/T in the shop working out some fuel issues. I'm trying to eliminate what may not be correct first, and then go from there. The car is a 440, 4bbl, 4spd, Dana rear end, w/ N96 ("Ramcharger" induction), and is a factory E.C.S. (California Emissions) car.
Two questions:
1. Does anyone have a schematic or pictures of where the additional ECS-specific emission hoses go under the hood? If you have pictures, I'd like for it to be of a correctly restored car, survivor, etc.
2. On a factory ECS car, should there be a fuel separator between the fuel pump and carb... like many big blocks had.
Thanks for your help!!
-Justin
1966 Dodge Charger
1968 Plymouth Satellite (Un-Restored "Survivor")
1969 Dodge Charger (W.B. General Lee)
1969 Dodge Charger (Future DMCL Clone)
1969 Dodge Super Bee, 383 4spd
Re: California-Built 1970 Coronet R/T Fuel Issues: HELP! [Re: CornDogsCharger] #2377895
09/27/17 07:46 PM
09/27/17 07:46 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Re: California-Built 1970 Coronet R/T Fuel Issues: HELP! [Re: CornDogsCharger] #2378209
09/28/17 12:19 PM
09/28/17 12:19 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Two questions:
-Justin
1. There is a hose from the carb bowl vent to the three nipple breather on the valve cover. Then another hose from the three nipple breather to a metal line on the passenger side inner fender. This line runs back to the vapor separator in the trunk.
2. There is a fuel separator because it is a 440. It has nothing to do with ECS.
Note the should be three fuel lines :
one 3/8" that goes from the fuel sender to the fuel pump
one 5/16" that goes from the fuel sender return to the fuel separator
one 5/16" that goes from the three nipple breather to the vapor separator in the trunk
Re: California-Built 1970 Coronet R/T Fuel Issues: HELP! [Re: CornDogsCharger] #2378216
09/28/17 12:35 PM
09/28/17 12:35 PM
South San Francisco, Ca
70sixpkrt Offline
70sixpkrt  Offline
how's this:
[img]http://www.imgur.com/hxlGUJt.gif[/img]
4-speed
3:54 Dana
13.01 @107.93 with street tires (not hooking up)
Re: California-Built 1970 Coronet R/T Fuel Issues: HELP! [Re: 70sixpkrt] #2378221
09/28/17 12:40 PM
09/28/17 12:40 PM
70sixpkrt Offline
70sixpkrt  Offline
Fuel Vapor Canister:
4-speed
3:54 Dana
Re: California-Built 1970 Coronet R/T Fuel Issues: HELP! [Re: 70sixpkrt] #2378233
09/28/17 12:51 PM
09/28/17 12:51 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Remember, that none of the repo casters have the .060 office in the return nipple like the originals did, so you will have to make your own. If you don't then your fuel pressure, and flow would probably be low.
Re: California-Built 1970 Coronet R/T Fuel Issues: HELP! [Re: 70sixpkrt] #2378245
09/28/17 12:58 PM
09/28/17 12:58 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Originally Posted By 70sixpkRT
how's this:
Gee, where's that picture come from?
Oh the FSM, wonder why someone doesn't get one and use it.
Don't be the exception.
Re: California-Built 1970 Coronet R/T Fuel Issues: HELP! [Re: Supercuda] #2378565
09/28/17 11:41 PM
09/28/17 11:41 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
how's this:
Because not everyone is loaded like you and me.
Re: California-Built 1970 Coronet R/T Fuel Issues: HELP! [Re: Morty426] #2379742
10/01/17 03:54 AM
10/01/17 03:54 AM
Spokane Valley, WA
Big Bad Bee Offline
Big Bad Bee  Offline
Spokane Valley, WA
how's this:
You don't have to be drunk to own an FSM. But it helps.
I’m listening.
Re: California-Built 1970 Coronet R/T Fuel Issues: HELP! [Re: Big Bad Bee] #2380052
10/01/17 05:18 PM
10/01/17 05:18 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
how's this:
LOL
Re: California-Built 1970 Coronet R/T Fuel Issues: HELP! [Re: Morty426] #2380515
10/02/17 12:18 PM
10/02/17 12:18 PM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
I had a 71 Charger with the ECS. The problem was I would get vapor lock on a hot day. Bought the car in the spring. Didn't drive it that much. When we restored the car the lines going into the new tank were blocked off. I left the return line in the eventI decided to go FI.
Blocking off the lines solved the problem.
Abe Lincoln
Re: California-Built 1970 Coronet R/T Fuel Issues: HELP! [Re: CornDogsCharger] #2380705
10/02/17 05:20 PM
10/02/17 05:20 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
1970 cars have ECS.
1971 cars have NOx.
They are not the same.
Re: California-Built 1970 Coronet R/T Fuel Issues: HELP! [Re: Alaskan_TA] #2381063
10/03/17 02:17 AM
10/03/17 02:17 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Originally Posted By Alaskan_TA
1970 cars have ECS.
1971 cars have NOx.
1970 California cars have ECS
All 71 cars have ECS
Some engines in 71 got NOx
