California-Built 1970 Coronet R/T Fuel Issues: HELP!
#2377872
09/27/17 06:55 PM
09/27/17 06:55 PM
Posts: 412 Jackson, Mississippi
CornDogsCharger
Hey guys, I've been searching and haven't really found an answer to this. We've got a 1970 Dodge Coronet R/T in the shop working out some fuel issues. I'm trying to eliminate what may not be correct first, and then go from there. The car is a 440, 4bbl, 4spd, Dana rear end, w/ N96 ("Ramcharger" induction), and is a factory E.C.S. (California Emissions) car.
Two questions: 1. Does anyone have a schematic or pictures of where the additional ECS-specific emission hoses go under the hood? If you have pictures, I'd like for it to be of a correctly restored car, survivor, etc.
2. On a factory ECS car, should there be a fuel separator between the fuel pump and carb... like many big blocks had.
Thanks for your help!! -Justin
1966 Dodge Charger 1968 Plymouth Satellite (Un-Restored "Survivor") 1969 Dodge Charger (W.B. General Lee) 1969 Dodge Charger (Future DMCL Clone) 1969 Dodge Super Bee, 383 4spd
Re: California-Built 1970 Coronet R/T Fuel Issues: HELP!
[Re: CornDogsCharger]
#2378209
09/28/17 12:19 PM
09/28/17 12:19 PM
Posts: 9,550 Sacramento CA
Morty426
Sacramento CA
Thanks for your help!! -Justin 1. There is a hose from the carb bowl vent to the three nipple breather on the valve cover. Then another hose from the three nipple breather to a metal line on the passenger side inner fender. This line runs back to the vapor separator in the trunk. 2. There is a fuel separator because it is a 440. It has nothing to do with ECS. Note the should be three fuel lines : one 3/8" that goes from the fuel sender to the fuel pump one 5/16" that goes from the fuel sender return to the fuel separator one 5/16" that goes from the three nipple breather to the vapor separator in the trunk
[Re: 70sixpkrt]
#2378245
09/28/17 12:58 PM
09/28/17 12:58 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
how's this: Gee, where's that picture come from? Oh the FSM, wonder why someone doesn't get one and use it.
[Re: Supercuda]
#2378565
09/28/17 11:41 PM
09/28/17 11:41 PM
Morty426
Sacramento CA
how's this: Gee, where's that picture come from? Oh the FSM, wonder why someone doesn't get one and use it. Because not everyone is loaded like you and me.
[Re: Morty426]
#2379742
10/01/17 03:54 AM
10/01/17 03:54 AM
Posts: 10,938 Spokane Valley, WA
Big Bad Bee
Spokane Valley, WA
how's this: Gee, where's that picture come from? Oh the FSM, wonder why someone doesn't get one and use it. Because not everyone is loaded like you and me. You don't have to be drunk to own an FSM. But it helps.
I’m listening.
[Re: Big Bad Bee]
#2380052
10/01/17 05:18 PM
10/01/17 05:18 PM
Morty426
Sacramento CA
how's this: Gee, where's that picture come from? Oh the FSM, wonder why someone doesn't get one and use it. Because not everyone is loaded like you and me. You don't have to be drunk to own an FSM. But it helps. LOL
[Re: Morty426]
#2380515
10/02/17 12:18 PM
10/02/17 12:18 PM
Posts: 16,145 Mesa, Arizona
dart4forte
Mesa, Arizona
I had a 71 Charger with the ECS. The problem was I would get vapor lock on a hot day. Bought the car in the spring. Didn't drive it that much. When we restored the car the lines going into the new tank were blocked off. I left the return line in the eventI decided to go FI. Blocking off the lines solved the problem.
Abe Lincoln
[Re: Alaskan_TA]
#2381063
10/03/17 02:17 AM
10/03/17 02:17 AM
Morty426
Sacramento CA
1970 cars have ECS.
1971 cars have NOx.
They are not the same. 1970 California cars have ECS All 71 cars have ECS Some engines in 71 got NOx
