My 440 is hurt. bottom end. #2375222
09/22/17 09:56 PM
09/22/17 09:56 PM
Sudbury, Ontario, Canada
ForcedInductions Offline OP
well i lost a pushrod from a failed retainer in the lifer.
shown here
Pushrod link
i went ahead and upgraded the rockers and rods
fired it up and quickly came a metal grinding noise.
like spur gears eating themselves, or metal in a pump.
so i shut it down. once cooled i decided to rock the crank back and forth.
this was its result.
ur honest guess. i haven't opened it up yet because its end of season. no money no funny.
and i don't like to leave blocks open for long periods with no pan/oil at least canadian winters are dry.
if its spun bearing, think i can get away without work on the crank?
if its end cap/stretched bolt yay?
i dont think its above the bearings as theres no knock or tick while running.
ie wrist pin or bent connecting rod. but sounds like valve train chatter from too advanced timing..
here is a vid of the top end put back together. you cant really hear it.
my guess the bent pushrod was from float/kissing or the pushup.
psi on oil never goes past 60 but i am running royal purple 20w60
no zinc or additives, about 700 miles on the build.
i guess whom ever guesses what it is and i do actually open it gets bragging rights?
Re: My 440 is hurt. bottom end. [Re: ForcedInductions] #2375226
09/22/17 10:03 PM
09/22/17 10:03 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
If it were me I'd drop the pan. Only way to see what really is going on in there.
Re: My 440 is hurt. bottom end. [Re: rickraw] #2375234
09/22/17 10:28 PM
09/22/17 10:28 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
sounds too tinny to be a bearing,more like, windage tray? crank scraper?, flex plate cracked or loose crank or converter bolts.
Re: My 440 is hurt. bottom end. [Re: dartman366] #2375242
09/22/17 10:45 PM
09/22/17 10:45 PM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
If it has a crank scraper on the pan that's my bet...
It's a very hollow sound...I don't think it's anything crank to rod related... maybe something heavy hitting something thin???
twocents
...FAFO...
Re: My 440 is hurt. bottom end. [Re: ForcedInductions] #2375253
09/22/17 11:18 PM
09/22/17 11:18 PM
Pittsburgh,PA
RTSrunner Offline
RTSrunner  Offline
Pittsburgh,PA
Could be a loose rod hitting the windage tray.I think flexplate/flywheel as a possibility too...hopefully!
RT
Re: My 440 is hurt. bottom end. [Re: RTSrunner] #2375279
09/23/17 12:19 AM
09/23/17 12:19 AM
N.W. Indiana
DblOJoe Offline
DblOJoe  Offline
N.W. Indiana
Converter bolts
Re: My 440 is hurt. bottom end. [Re: ForcedInductions] #2375283
09/23/17 12:27 AM
09/23/17 12:27 AM
P
Porter67 Offline
Porter67  Offline
P
Id say vert bolts or flex plate issue as well, the noise is external imo.
Amazed over your oem rockers, what cam, ect?
Re: My 440 is hurt. bottom end. [Re: ForcedInductions] #2375293
09/23/17 12:44 AM
09/23/17 12:44 AM
cam specs are lost to the wind when i put them in 2001.
oem seems to work fine. custom ported heads, larger valves.
i worked for a machine shop back in those days.
Re: My 440 is hurt. bottom end. [Re: ForcedInductions] #2375295
09/23/17 12:46 AM
09/23/17 12:46 AM
ill pop open the inspection plate in the morning, possibly the pan.
i hope its the bolts. i don't even recall if i put in grade 8 or 5.
as for windage it does have one but if its getting hit
must mean something caused it to move or something is loose to hit it. ie rod cap/bearing
Re: My 440 is hurt. bottom end. [Re: ForcedInductions] #2375296
09/23/17 12:51 AM
09/23/17 12:51 AM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
Can u rotate the engine 360*
Re: My 440 is hurt. bottom end. [Re: ForcedInductions] #2375420
09/23/17 12:24 PM
09/23/17 12:24 PM
oh yeah no issues or hard points.
hissing can be heard during partial compression/overlaps/exhaust.
runs fine little metal noise then when shut down can hear that metal rattle.
im starting to think it is the torque converter bolts
will know in a few hours when i take the inspection plate off.
Re: My 440 is hurt. bottom end. [Re: ForcedInductions] #2375428
09/23/17 12:43 PM
09/23/17 12:43 PM
North Dakota
Azzkikrcuda Offline
Azzkikrcuda  Offline
North Dakota
I would take the oil filter off and cut it open or dump the oil out of it into a clean tray first. Depending on what you see that should tell if it is a bearing or something else before you take it apart.
The only Carbs I care about are under the hood!
Re: My 440 is hurt. bottom end. [Re: ForcedInductions] #2375513
09/23/17 03:05 PM
09/23/17 03:05 PM
Converter bolts that have came loose will only make noise when they are hitting somewhere behind the block, they make metal when they hit also work scope
Your deal does NOT sound like that at all confused
Let us know what you find up
Re: My 440 is hurt. bottom end. [Re: Cab_Burge] #2375515
09/23/17 03:08 PM
09/23/17 03:08 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
Re: My 440 is hurt. bottom end. [Re: RSNOMO] #2375522
09/23/17 03:24 PM
09/23/17 03:24 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
I would cut the oil filter open but then again I bought a tool from Summit years ago that makes that job as easy as opening up a can of soup.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: My 440 is hurt. bottom end. [Re: pittsburghracer] #2375529
09/23/17 03:33 PM
09/23/17 03:33 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
After listening again it sounds like slop in the converter bolts. The sound is dense.
Re: My 440 is hurt. bottom end. [Re: ForcedInductions] #2375543
09/23/17 04:33 PM
09/23/17 04:33 PM
all 4 was converter bolts. one was completely out thankfully no damage
replaced them all and used red lock tight this time
i will hate myself later but what the heck. cheers guys!
i did notice the snout on the starter was cracked and loose but not coming out. c'est la vie
Re: My 440 is hurt. bottom end. [Re: ForcedInductions] #2375545
09/23/17 04:39 PM
09/23/17 04:39 PM
PA.
"Little"John
"Little"John
PA.
Every time a converter bolt goes in my car the bolts are wire wheeled, cleaned in lacquer thinner, and red lock-tite is used. Lock-tite does not like oil
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: My 440 is hurt. bottom end. [Re: ForcedInductions] #2375567
09/23/17 05:34 PM
09/23/17 05:34 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
That was a close call with those tc bolts.no leaks is a good thing.
Re: My 440 is hurt. bottom end. [Re: ForcedInductions] #2375666
09/23/17 08:44 PM
09/23/17 08:44 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Good catch but I'm trippin on stock rockers in a blown motor.......... shruggy
