2206158 Crankshaft casting question
#2369072
09/11/17 10:43 PM
09/11/17 10:43 PM
Posts: 786 Shawnee, Kansas
Ebbsspeed
Shawnee, Kansas
I have an elderly friend who raced a Max Wedge car in the 70's, and he collected a lot of MW specific parts when he ran across them. He asked me to sell the stuff for him, and I ran across one piece I'm a bit confused about. He has a crankshaft with a casting number of 2206158, with an 8-bolt flywheel flange. None of the info I've been able to find says that casting had an 8 bolt flange. Any idea as to what it may have been in originally would be appreciated.
I may not appear to be doing much, but on the cellular level I'm really quite busy!
Re: 2206158 Crankshaft casting question
[Re: Ebbsspeed]
#2369269
09/12/17 09:31 AM
09/12/17 09:31 AM
Posts: 6,096 Valencia, España
NachoRT74
Valencia, España
Aren't Hemis with 8 bolts ?
[Re: NachoRT74]
#2369283
09/12/17 10:12 AM
09/12/17 10:12 AM
Ebbsspeed
Shawnee, Kansas
Yes, the hemi has an 8 bolt flange. I guess the charts I've seen do say that casting was used in 426 cars from 1963 to 196, so that must be it. That casting was also used in 1971 to 1977 truck 440's, and I believe the trucks also used an 8 bolt flange, so it may have come from one of those as well.
[Re: Ebbsspeed]
#2369563
09/12/17 06:34 PM
09/12/17 06:34 PM
Posts: 25,858 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The 2206158 forging was used in various RB motors from '62 until the end of production. The flange could have been drilled either 6 or 8 holes.
[Re: dogdays]
#2369860
09/13/17 02:06 AM
09/13/17 02:06 AM
Ebbsspeed
Shawnee, Kansas
There is NO Max Wedge crankshaft with a casting number!!!!!!!!!!!!!!!!!!!!! Unless your friend had the only Max Wedge in history with a cast crank.
A casting number is part of the mold into which the molten metal is poured to form the casting. Thus, a casting number will always be raised above the surrounding surface.
A forging number is beat (pressed) into the metal being formed into a crankshaft sometime during the forging process and thus will nearly always be indented into the surface.
Let's keep the facts straight. Talking about casting numbers insults a forged crank.
R. Then maybe this is one of those rare forged cranks that has a "number" raised above the surrounding surface, instead of indented. Like a casting would.
[Re: Ebbsspeed]
#2370113
09/13/17 03:28 PM
09/13/17 03:28 PM
Ebbsspeed
Shawnee, Kansas
Semantics. Valve covers would more accurately be called rocker arm covers. A Xerox copy may not have ever been near a Xerox manufactured machine.
I understand that the numbers on a forging are not literally "casting" numbers, however, they're called casting numbers on more reference sites than not.
In the future I'll try to be more anal when I ask questions.
[Re: Ebbsspeed]
#2370148
09/13/17 04:18 PM
09/13/17 04:18 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Don't ever say frame off around here or kitten will be shat out at prodigious rates.
Even if it's a truck
[Re: Ebbsspeed]
#2370181
09/13/17 04:57 PM
09/13/17 04:57 PM
John_Kunkel
Rio Linda, CA
Semantics.
I understand that the numbers on a forging are not literally "casting" numbers, however, they're called casting numbers on more reference sites than not. Numerous wrongs don't make a right.
[Re: 70HemiGTX]
#3201162
12/31/23 02:50 PM
12/31/23 02:50 PM
Posts: 5,850 ohio
ruderunner
ohio
Didn't early big blocks have an extended flange? I think pre 62.
Angry white pureblood male
[Re: IMGTX]
#3201189
12/31/23 04:25 PM
12/31/23 04:25 PM
Posts: 6,280 nowhere
Sniper
nowhere
Those are little before my time so how did the crank connect to the flywheel/ flexplate without threads? Through bolts with nuts? Yes, same as the old flatheads did. Not sure why they thought that was a good idea back then,
[Re: Sniper]
#3201192
12/31/23 04:43 PM
12/31/23 04:43 PM
Posts: 10,731 North Dakota
6PakBee
North Dakota
Those are little before my time so how did the crank connect to the flywheel/ flexplate without threads? Through bolts with nuts? Yes, same as the old flatheads did. Not sure why they thought that was a good idea back then, I'm guessing so you could check the torque converter/flywheel attachment nut torque without disassembling the whole assembly. Same kind of thinking that led to left hand lugnuts.
[Re: ruderunner]
#3201251
12/31/23 09:58 PM
12/31/23 09:58 PM
Posts: 43,218 Bend,OR USA
Cab_Burge
Didn't early big blocks have an extended flange? I think pre 62. Your correct on that, 1962 was the first year of all aluminum one piece BB 727 front case with the shorter crankshafts that had the threaded flanges that use bolts to hold the flex plate or flywheels to the crankshaft along with the converter flywheel alignment ring around the center of the crankshafts to align the flywheel s or flex plates, they didn't fit over the outside diameter of the rear crankshaft flanges like the pre 1962 motor used The all aluminum case 727 1962 in Dodges and Plymouths and later cars were way better designed and lasted a lot longer with hard abuse than the 1961 and earlier cast iron torque Flyte did: up:
