2206158 Crankshaft casting question #2369072
09/11/17 10:43 PM
09/11/17 10:43 PM
Shawnee, Kansas
E
Ebbsspeed Offline OP
E
Shawnee, Kansas
I have an elderly friend who raced a Max Wedge car in the 70's, and he collected a lot of MW specific parts when he ran across them. He asked me to sell the stuff for him, and I ran across one piece I'm a bit confused about. He has a crankshaft with a casting number of 2206158, with an 8-bolt flywheel flange. None of the info I've been able to find says that casting had an 8 bolt flange. Any idea as to what it may have been in originally would be appreciated.
I may not appear to be doing much, but on the cellular level I'm really quite busy!
Re: 2206158 Crankshaft casting question [Re: Ebbsspeed] #2369269
09/12/17 09:31 AM
09/12/17 09:31 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
Aren't Hemis with 8 bolts ?
Re: 2206158 Crankshaft casting question [Re: NachoRT74] #2369283
09/12/17 10:12 AM
09/12/17 10:12 AM
Shawnee, Kansas
E
E
Shawnee, Kansas
Yes, the hemi has an 8 bolt flange. I guess the charts I've seen do say that casting was used in 426 cars from 1963 to 196, so that must be it. That casting was also used in 1971 to 1977 truck 440's, and I believe the trucks also used an 8 bolt flange, so it may have come from one of those as well.
Re: 2206158 Crankshaft casting question [Re: Ebbsspeed] #2369421
09/12/17 02:38 PM
09/12/17 02:38 PM
dogdays Offline
dogdays  Offline
There is NO Max Wedge crankshaft with a casting number!!!!!!!!!!!!!!!!!!!!!
Unless your friend had the only Max Wedge in history with a cast crank.
A casting number is part of the mold into which the molten metal is poured to form the casting. Thus, a casting number will always be raised above the surrounding surface.
A forging number is beat (pressed) into the metal being formed into a crankshaft sometime during the forging process and thus will nearly always be indented into the surface.
Let's keep the facts straight. Talking about casting numbers insults a forged crank.
R.
Re: 2206158 Crankshaft casting question [Re: Ebbsspeed] #2369563
09/12/17 06:34 PM
09/12/17 06:34 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The 2206158 forging was used in various RB motors from '62 until the end of production. The flange could have been drilled either 6 or 8 holes.
Re: 2206158 Crankshaft casting question [Re: dogdays] #2369860
09/13/17 02:06 AM
09/13/17 02:06 AM
Shawnee, Kansas
E
E
Shawnee, Kansas
R.
Then maybe this is one of those rare forged cranks that has a "number" raised above the surrounding surface, instead of indented.
Like a casting would.
Re: 2206158 Crankshaft casting question [Re: Ebbsspeed] #2369891
09/13/17 05:18 AM
09/13/17 05:18 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
yes, there can be "raised" forging numbers - the point was, A FORGED CRANK DOES NOT HAVE CASTING NUMBERS
Re: 2206158 Crankshaft casting question [Re: Ebbsspeed] #2370113
09/13/17 03:28 PM
09/13/17 03:28 PM
Shawnee, Kansas
E
E
Shawnee, Kansas
Semantics. Valve covers would more accurately be called rocker arm covers. A Xerox copy may not have ever been near a Xerox manufactured machine.
I understand that the numbers on a forging are not literally "casting" numbers, however, they're called casting numbers on more reference sites than not.
In the future I'll try to be more anal when I ask questions.
Re: 2206158 Crankshaft casting question [Re: Ebbsspeed] #2370148
09/13/17 04:18 PM
09/13/17 04:18 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Don't ever say frame off around here or kitten will be shat out at prodigious rates.
Even if it's a truck
Don't be the exception.
Re: 2206158 Crankshaft casting question [Re: Ebbsspeed] #2370181
09/13/17 04:57 PM
09/13/17 04:57 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Originally Posted By Ebbsspeed
Semantics.
Numerous wrongs don't make a right.
Re: 2206158 Crankshaft casting question [Re: John_Kunkel] #3201155
12/31/23 02:31 PM
12/31/23 02:31 PM
PA
70HemiGTX Offline
70HemiGTX  Offline
PA
To revive an old post, I looked at a crankshaft this morning with the raised numbers on it. An old guy has it. He used to rebuild engines and would buy crankshaft kits. The box was marked Chrysler 426 Hemi and the part number 2206158 on the box and on the crank. It also was listed like that in a TRW catalog he had there. It had an 8 bolt flange and everthing else was a perfect match for a Hemi crankshaft. There was one problem, the flange end was about 1/2" longer than the crank I took along for comparison. The guy's daughter had sent me some pictures and I noticed something odd, but she was clueless and I talked to the man on the phone about it. He was positive it was for a Hemi. So I took an old crank along for comparison. I'm just curious as to what the application is for this crankshaft. The main seal surface is approximately double the width of a normal crankshaft. It was drilled for a 4 spd and had a pilot bushing in it. What the heck is this for ???? I will attach some pics.
Re: 2206158 Crankshaft casting question [Re: 70HemiGTX] #3201162
12/31/23 02:50 PM
12/31/23 02:50 PM
ohio
ruderunner Offline
ruderunner  Offline
ohio
Didn't early big blocks have an extended flange? I think pre 62.
Angry white pureblood male
Re: 2206158 Crankshaft casting question [Re: 70HemiGTX] #3201163
12/31/23 02:52 PM
12/31/23 02:52 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Pre 63? cranks had an extended snout. Probably was an RB crank, and if the holes were not threaded that is exactly what it is.
http://www.forwardlook.net/forums/forums/thread-view.asp?tid=26101
Re: 2206158 Crankshaft casting question [Re: Sniper] #3201175
12/31/23 03:29 PM
12/31/23 03:29 PM
A727Tflite Offline
A727Tflite  Offline
Pre 62
Re: 2206158 Crankshaft casting question [Re: Sniper] #3201187
12/31/23 04:23 PM
12/31/23 04:23 PM
IMGTX Offline
IMGTX  Offline
Those are little before my time so how did the crank connect to the flywheel/ flexplate without threads?
Through bolts with nuts? shruggy
Re: 2206158 Crankshaft casting question [Re: IMGTX] #3201189
12/31/23 04:25 PM
12/31/23 04:25 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Yes, same as the old flatheads did. Not sure why they thought that was a good idea back then,
Re: 2206158 Crankshaft casting question [Re: Sniper] #3201192
12/31/23 04:43 PM
12/31/23 04:43 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
I'm guessing so you could check the torque converter/flywheel attachment nut torque without disassembling the whole assembly. Same kind of thinking that led to left hand lugnuts.
Re: 2206158 Crankshaft casting question [Re: 6PakBee] #3201197
12/31/23 05:03 PM
12/31/23 05:03 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Well, on the flatheads, the nut was on the clutch side of the flywheel and the special bolts had a flat that rode against a ring on the crank to keep them from spinning. So I don't see that benefit there. As for the V8's, I dunno I looked in a 1960 Dodge FSM and parts manual, no real help figuring that out in either one.
Re: 2206158 Crankshaft casting question [Re: ruderunner] #3201251
12/31/23 09:58 PM
12/31/23 09:58 PM
Your correct on that, 1962 was the first year of all aluminum one piece BB 727 front case with the shorter crankshafts that had the threaded flanges that use bolts to hold the flex plate or flywheels to the crankshaft along with the converter flywheel alignment ring around the center of the crankshafts to align the flywheel s or flex plates, they didn't fit over the outside diameter of the rear crankshaft flanges like the pre 1962 motor used scope shruggy
The all aluminum case 727 1962 in Dodges and Plymouths and later cars were way better designed and lasted a lot longer with hard abuse than the 1961 and earlier cast iron torque Flyte did: up:
Re: 2206158 Crankshaft casting question [Re: Sniper] #3201259
12/31/23 10:24 PM
12/31/23 10:24 PM
IMGTX Offline
IMGTX  Offline
Very interesting.
Learn something new every day. up
