AN size for lifter oiling #2364513
09/03/17 12:48 PM
09/03/17 12:48 PM
Yakima, WA
K
kevinlc Offline OP
kevinlc  Offline OP
K
Yakima, WA
Having the Indy block drilled for individual lifter oiling. What size -3 or -4 or ???? And was thinking about a #6 main line size. Thoughts.....
Re: AN size for lifter oiling [Re: kevinlc] #2364521
09/03/17 12:57 PM
09/03/17 12:57 PM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
-3 and my whole plumbing is restricted/fed by a .050 nitrous jet
....BAD A$$ STREET CAR.....
Re: AN size for lifter oiling [Re: n20mstr] #2364654
09/03/17 03:46 PM
09/03/17 03:46 PM
iagree
OP, what type of rockers are you using, ductile iron, extruded aluminum or full roller aluminum?
If aluminum roller rockers use a smaller restrictor like .040 or so twocents
Re: AN size for lifter oiling [Re: Cab_Burge] #2364676
09/03/17 04:11 PM
09/03/17 04:11 PM
Yakima, WA
K
kevinlc Offline OP
kevinlc  Offline OP
K
Yakima, WA
T&D rockers on a common shaft.
Re: AN size for lifter oiling [Re: kevinlc] #2364683
09/03/17 04:22 PM
09/03/17 04:22 PM
warren, mich.
dwayne welder Offline
warren, mich.
Call T&D for there recommendations!!!!
Re: AN size for lifter oiling [Re: dwayne welder] #2364829
09/03/17 08:54 PM
09/03/17 08:54 PM
NY
challenger451ci Offline
NY
-03 AN here too. I used an 0.040 flare jet in each lifter bore feed line. I had about 65psi of oil pressure priming the pump with no lifters in the bores so I figured I was pretty safe if I launch a lifter. I tapped the holes 1/16" NPT.
Re: AN size for lifter oiling [Re: challenger451ci] #2365967
09/05/17 07:31 PM
09/05/17 07:31 PM
Yakima, WA
K
kevinlc Offline OP
kevinlc  Offline OP
K
Yakima, WA
Do you guys think the -6 main oil feed line to the distribution block is to big then?
Re: AN size for lifter oiling [Re: kevinlc] #2366038
09/05/17 09:13 PM
09/05/17 09:13 PM
Absolutely down
Run the same size feed line to the distribution block as you run to the heads, unless you already ran it twocents up
Re: AN size for lifter oiling [Re: kevinlc] #2366046
09/05/17 09:23 PM
09/05/17 09:23 PM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
If you haven't started the process yet, send the block to westin, or industrial boring and have normal lifter oil galleys drilled into the block. The lines, fittings, and time are more than just having the galleys drilled. JM2cents
Re: AN size for lifter oiling [Re: kevinlc] #2366055
09/05/17 09:42 PM
09/05/17 09:42 PM
I reread your post, I assumed it was about rocker arm shaft oiling, not the lifter galley blush
Ignore everything I posted, I have never done what your doing blush
Re: AN size for lifter oiling [Re: kevinlc] #2366096
09/05/17 10:50 PM
09/05/17 10:50 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Is there some advantage to individual lifter oiling ?!?!?
Re: AN size for lifter oiling [Re: Stanton] #2366109
09/05/17 11:06 PM
09/05/17 11:06 PM
Yakima, WA
K
kevinlc Offline OP
kevinlc  Offline OP
K
Yakima, WA
This block I have has no oiling to the lifters.
Re: AN size for lifter oiling [Re: kevinlc] #2366129
09/05/17 11:39 PM
09/05/17 11:39 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Your fittings would be 1/8" before being compressed
but you only need about .015 per rocker it be good..
so if you figure what .015 per rocker anything bigger
per rocker adds up to a lot.. I kept going smaller on
my SB stuff to get it right.. it takes very little oil
on the TD rockers to have them live..all I run is TD stuff
wave
