Re: AN size for lifter oiling
[Re: n20mstr]
#2364654
09/03/17 03:46 PM
09/03/17 03:46 PM
Posts: 43,223 Bend,OR USA
Cab_Burge
-3 and my whole plumbing is restricted/fed by a .050 nitrous jet OP, what type of rockers are you using, ductile iron, extruded aluminum or full roller aluminum? If aluminum roller rockers use a smaller restrictor like .040 or so
[Re: kevinlc]
#2366038
09/05/17 09:13 PM
09/05/17 09:13 PM
Cab_Burge
Do you guys think the -6 main oil feed line to the distribution block is to big then? Absolutely Run the same size feed line to the distribution block as you run to the heads, unless you already ran it
[Re: kevinlc]
#2366129
09/05/17 11:39 PM
09/05/17 11:39 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Your fittings would be 1/8" before being compressed but you only need about .015 per rocker it be good.. so if you figure what .015 per rocker anything bigger per rocker adds up to a lot.. I kept going smaller on my SB stuff to get it right.. it takes very little oil on the TD rockers to have them live..all I run is TD stuff
