66 Fury disc brake conversion #2362783
08/31/17 11:44 AM
08/31/17 11:44 AM
Georgia
K
KingTuna Offline OP
KingTuna  Offline OP
K
Georgia
Alright, I've been focusing on life for the last year and a half and have neglected the poor Fury. Had a kid last December, and am currently working on closing on the house we are currently renting. The house has a shop, so I finally have a space to work on the Fury.
I have the spindles and rotors off of my 73 New Yorker parts car. If I remember correctly from researching it, I need to use the lower ball joints off of the Fury onto the New Yorker spindle. I plan on upgrading the master cylinder and booster down the road, but for now, I plan on running the master cylinder and power drum booster. I know that it won't have enough pressure for full on hard stops, but it will still be better than the drums now. Currently, the wheel cylinders are shot, and the pedal goes almost to the floor.
One more question, I noticed yesterday that while pressing the brakes the car did not want to idle in gear. Idles fine in park or neutral. Before the wheel cylinders completely quit, I did not have a problem. Would this have an effect on the idle, or is it just time to do some adjusting on the carb?
2014 Ram 1500 Pentastar V6
1966 Fury II 4 door
Re: 66 Fury disc brake conversion [Re: KingTuna] #2362790
08/31/17 11:59 AM
08/31/17 11:59 AM
RapidRobert Online content
RapidRobert  Online Content
could need mixture screw adjustment (or internal carb cleaning) or the booster could have a vac leak. put the ebrake on & idling in gear & if it is still idling clean then press the brake pedal & see if the idle acts up.
Re: 66 Fury disc brake conversion [Re: KingTuna] #2362794
08/31/17 12:08 PM
08/31/17 12:08 PM
Andrewh Offline
Andrewh  Offline
The ball joints are the same as I recall. the catch is the bolts need to be the old ones. the new ones don't go all the way through.
but yes to be safe use the old ball joints from the 66.
you need new hoses and pay attention if you have or ever plan on putting on a sway bar, mount the calipers to the rear.
The brackets stay on the side they are on, the spindles swap and so do the calipers so the bleeders still point up.
Re: 66 Fury disc brake conversion [Re: KingTuna] #2362805
08/31/17 12:31 PM
08/31/17 12:31 PM
Georgia
K
KingTuna Offline OP
KingTuna  Offline OP
K
Georgia
RapidRobert, that is a great idea and I'll try it out when I get home today. It probably does the mixture adjusted, the exhaust was smelling a little rich, but that problem was new.
Andrewh, thank you. I'll be buying some new flex hoses when I install the disc brakes.
Looking forward to getting the old girl back on the road!
1966 Fury II 4 door
Re: 66 Fury disc brake conversion [Re: KingTuna] #2362863
08/31/17 02:26 PM
08/31/17 02:26 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
The booster can be bad - could have a large vacuum leak when pressing the brakes. Check the booster.
Re: 66 Fury disc brake conversion [Re: KingTuna] #2363160
09/01/17 12:00 AM
09/01/17 12:00 AM
Georgia
K
KingTuna Offline OP
KingTuna  Offline OP
K
Georgia
Well, car still wanted to stall with the parking brake set and in gear, so not the booster. I leaned out the mixture a little bit and brought the idle up some and she idles nicely. I forgot that last year before we moved, I had taken off the Torker that came on the engine and installed the Edelbrock Performer. I would bet money that's why she was off. I still need to get my brother in law to hook up the vacuum gauges and get the carb just right. Thank yall for the help!
1966 Fury II 4 door
