priming oil #2348365
08/04/17 12:00 PM
08/04/17 12:00 PM
mass
raybee Offline OP
raybee  Offline OP
mass
HI I am getting ready to start my 440 six pack motor,i am trying to get the oil up by turning the oil pump with a drill, nothing is coming out the push rods to the rockers do I need a high speed drill to turn the shaft?
Re: priming oil [Re: raybee] #2348379
08/04/17 12:15 PM
08/04/17 12:15 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
Turn the engine 90* to open the cam passage the the rockers.
Re: priming oil [Re: raybee] #2348383
08/04/17 12:25 PM
08/04/17 12:25 PM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
Are you turning counter clockwise?
Did you change to pushrod oiling? Standard is up through rocker stand into rocker shafts, then to rockers.
Joe
Re: priming oil [Re: jlatessa] #2348388
08/04/17 12:32 PM
08/04/17 12:32 PM
put the dampener slit to TDC on #6 compression & preoil one bank then turn the dampener back 3/4 turn CCW (guestimate or cut a strip of paper 17.082" to use as a ruler) then preoil the other bank. I like to get it on #8 first during assy then preoil then go forward to the slit for #6 then I just have to back it up slightly to 15 deg to set the timing all of which minimizes the amt the camshaft being turned.
Re: priming oil [Re: raybee] #2348679
08/04/17 09:44 PM
08/04/17 09:44 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
I should hope not. 440's do not oil out the pushrods.
Chevies do though, might want to reconsider.
Don't be the exception.
Re: priming oil [Re: raybee] #2348728
08/04/17 11:21 PM
08/04/17 11:21 PM
Australia
O
ozymaxwedge Offline
ozymaxwedge  Offline
O
Australia
As said above, turn the engine, reverse the drill and NO you dont need a high speed drill, you need a powerful drill turning slow.
1963 Plymouth Max Wedge
1971 Barracuda
