Re: priming oil
[Re: jlatessa]
#2348388
08/04/17 12:32 PM
08/04/17 12:32 PM
RapidRobert
put the dampener slit to TDC on #6 compression & preoil one bank then turn the dampener back 3/4 turn CCW (guestimate or cut a strip of paper 17.082" to use as a ruler) then preoil the other bank. I like to get it on #8 first during assy then preoil then go forward to the slit for #6 then I just have to back it up slightly to 15 deg to set the timing all of which minimizes the amt the camshaft being turned.
Re: priming oil
[Re: raybee]
#2348679
08/04/17 09:44 PM
08/04/17 09:44 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
nothing is coming out the push rods to the rockers
I should hope not. 440's do not oil out the pushrods.
Chevies do though, might want to reconsider.
Re: priming oil
[Re: raybee]
#2348728
08/04/17 11:21 PM
08/04/17 11:21 PM
Posts: 1,096 Australia
ozymaxwedge
Australia
As said above, turn the engine, reverse the drill and NO you dont need a high speed drill, you need a powerful drill turning slow.
1963 Plymouth Max Wedge 1971 Barracuda
