Help with tranny kick down and throttle cable ideas #2343438
07/26/17 12:49 AM
07/26/17 12:49 AM
None
71rm23 Offline OP
71rm23  Offline OP
None
I'm working on putting the final touches on my engine before initial start up. Have a 400 stroked engine with a Quick Fuel (like a Holley) 4 barrel carb. Have throttle return springs coming. What have anyone used for the throttle and kick down and bracketry? I don't have any of the factory setup so more than likely will have to be aftermarket. I thought there was some members here that used a throttle cable from a pick-up before(?). Any help will be appreciated, thanks
Re: Help with tranny kick down and throttle cable ideas [Re: 71rm23] #2343444
07/26/17 01:01 AM
07/26/17 01:01 AM
from all that I have read concerning lokar and bouchillion cable/kickdown problems just me I would highly suggest locating some OE stuff. I would think alot of of that stuff spans alot of years.
Re: Help with tranny kick down and throttle cable ideas [Re: 71rm23] #2343468
07/26/17 01:53 AM
07/26/17 01:53 AM
North Dakota
Azzkikrcuda Offline
Azzkikrcuda  Offline
North Dakota
Hit the junkyard and get the kick down cable setup off a 94-2001 durango, dakota or ram pickup. Then I use this throttle bracket http://www.jegs.com/i/JEGS-Performance-Products/555/15154/10002/-1 and make a bracket to hold the kick down cable. Works good, this is the setup bouchillion uses. Way better then the Loker setup. I will post a pick when a get a chance.
The only Carbs I care about are under the hood!
Re: Help with tranny kick down and throttle cable ideas [Re: 71rm23] #2343914
07/26/17 09:30 PM
07/26/17 09:30 PM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
Have you ever considered a manual valve body? I put them in everything and would never go back to automatic function.
Re: Help with tranny kick down and throttle cable ideas [Re: 71rm23] #2343932
07/26/17 09:56 PM
07/26/17 09:56 PM
AndyF Offline
AndyF  Offline
Mancini Racing sells all of that stuff and so does Hughes Engines. You can buy reproduction kick down linkages and taller throttle brackets and most everything you need.
Re: Help with tranny kick down and throttle cable ideas [Re: Azzkikrcuda] #2343977
07/26/17 11:12 PM
07/26/17 11:12 PM
North Dakota
Azzkikrcuda Offline
Azzkikrcuda  Offline
North Dakota
Pics
Re: Help with tranny kick down and throttle cable ideas [Re: RapidRobert] #2344176
07/27/17 11:15 AM
07/27/17 11:15 AM
moparx Offline
moparx  Offline
i have removed 12 or so lokar setups and replaced them all with factory pieces. the reasons this was done ranged from cheap, easily bent with use, bracketry to incorrect transmission adjustment ratio problems. at times, the factory replacement pieces required modifications because of intake manifold choices, but this inconvenience was way outweighed by correct transmission operation, as well as factory correct appearance, over the lokar stuff. i believe the main reason for the lokar problems lie in the design of the components, as these appear to be a GM design, modified [poorly, in my opinion] to fit the mopar application without thought to the proper carb to trans lever ratio. with that said, there are some that say the lokar setup works. that may be fine for them, but just because something "works", doesn't mean it "works correctly". i don't like the lokar setup, and strongly recommend staying away from it, using instead, a factory linkage [modified if necessary] or a manual valve body [as has been mentioned].
beer
Re: Help with tranny kick down and throttle cable ideas [Re: 71rm23] #2344783
07/28/17 12:22 PM
07/28/17 12:22 PM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
I agree with everything posted so far. I tried modifying the 2 BBL setup to work on a 4 with no luck on my 318. Tried a 340 4BBL set up and could not get it to work either and settled for the Bouchillon. Of course none of this applies to big block but it does give you a basis for thinking about this. Lokar seems to go on no car and work right.
I was not aware of the Durango mod. I could have taken that off mine when I donated it.
Good luck,
Craig
Re: Help with tranny kick down and throttle cable ideas [Re: 71rm23] #2344863
07/28/17 03:04 PM
07/28/17 03:04 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Use OEM or modify OEM, the aftermarket cable stuff SUCKS.
Coming soon!!!!
Re: Help with tranny kick down and throttle cable ideas [Re: 71rm23] #2344874
07/28/17 03:26 PM
07/28/17 03:26 PM
near Kansas City
igozumn Offline
igozumn  Offline
near Kansas City
Put a Bouchillon kickdown kit on a friend's LiL Red a month or so back. Whatever was on there wasn't original, or didn't match the parts book. Plus, aftermarket carb, etc. it just didn't work right. The Bouchillon kit was awesome and has performed exactly as needed.
