Hit the junkyard and get the kick down cable setup off a 94-2001 durango, dakota or ram pickup. Then I use this throttle bracket http://www.jegs.com/i/JEGS-Performance-Products/555/15154/10002/-1 and make a bracket to hold the kick down cable. Works good, this is the setup bouchillion uses. Way better then the Loker setup. I will post a pick when a get a chance.
The only Carbs I care about are under the hood!
