12v power source key on and cranking? #2340118
07/20/17 01:16 AM
07/20/17 01:16 AM
Laveen, Arizona
GTSDart340 Offline OP
Laveen, Arizona
68 Dart, what wires have full battery power with the key in the start and the run positions? I need to run the power for my fitech efi. Thanks!
1949 International KB-2 "Mater" - 302/T5
1968 Dodge Dart GTS "The Drat" - 340/727
2006 Dodge Magnum R/T - Hemi
2016 Dodge Durango Limited - 3.6
Re: 12v power source key on and cranking? [Re: GTSDart340] #2340122
07/20/17 01:20 AM
07/20/17 01:20 AM
brown wire ign2 (crank). blue wire ign1 (run). www.mymopar.com will have the locations coming out of the bulkhead so you can T into them.
Re: 12v power source key on and cranking? [Re: GTSDart340] #2340123
07/20/17 01:22 AM
07/20/17 01:22 AM
Laveen, Arizona
Laveen, Arizona
I need one wire that has both... Does that exist on my car?
Re: 12v power source key on and cranking? [Re: GTSDart340] #2340127
07/20/17 01:33 AM
07/20/17 01:33 AM
Thigh-Gap Junction
@#$%&*! Offline
New user name, Same old jerk!
@#$%&*!  Offline
Thigh-Gap Junction
NO!
You can tie the two wires together if you don't need a ballast resistor. If the starter relay wants to activate in the 'Run' position a diode will fix that. But I don't think that's an issue, just a possibility.
Find a wiring diagram if you don't have one.
Re: 12v power source key on and cranking? [Re: GTSDart340] #2340132
07/20/17 01:46 AM
07/20/17 01:46 AM
Laveen, Arizona
Laveen, Arizona
I do need the resistor... How would I run the wire with the resistor in place?
Re: 12v power source key on and cranking? [Re: GTSDart340] #2340141
07/20/17 02:09 AM
07/20/17 02:09 AM
Thigh-Gap Junction
@#$%&*! Offline
@#$%&*!  Offline
Thigh-Gap Junction
It depends on what the connection is needed for. If all it does is tell the FI to turn on you could probably connect to the blue side of the ballast resistor (or coil, voltage regulator or alternator, they're all tied together) and the small voltage loss won't matter. People have been hooking up the OE electronic ignitions this way for years. They do run into weak spark when cranking fairly often though. If it's a power feed you need a relay setup might be in order.
That should stir up a hornets nest of replies for you to ponder.
Re: 12v power source key on and cranking? [Re: GTSDart340] #2340157
07/20/17 04:35 AM
07/20/17 04:35 AM
Laveen, Arizona
Laveen, Arizona
It is the on/off circuit. I'm going to call fitech tomorrow and see if it makes any difference.
Re: 12v power source key on and cranking? [Re: GTSDart340] #2340162
07/20/17 05:16 AM
07/20/17 05:16 AM
Pennsylvania
P
polaris400cc Offline
P
Pennsylvania
I also ran mine off the ballast resistor wire, but I used a relay setup so I wouldn't run into any issues pulling power from that wire. Then you have a good source that's not on the old wiring harneess for any other stuff you want to tap for power, and can just tee off the signal wire for additional relays.
Re: 12v power source key on and cranking? [Re: GTSDart340] #2340207
07/20/17 10:08 AM
07/20/17 10:08 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
Has being discused latelly. It will depends if the added system requieres a steady 12 volts signal or just a 5 to 12 volt signal is enough for remote on ths system and the 12 volts power source is feeded from batt/alt. ( like MSD Ign box ).
Also depends on what else is accomplishing the system
If just for triggering on and the system support the ballast decay, the blue wire at ballast or regulator should be enough, because wihile cranking the power comes back from ign2 circuit through the ballast. Which is usually around 6-9volts. But just while crankiing
Re: 12v power source key on and cranking? [Re: GTSDart340] #2340208
07/20/17 10:15 AM
07/20/17 10:15 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
If ballast is required, NEVER feeds anything from coil wire because will vary the voltage rate coming from ballast to feed the coil. The coil wire lead must remain clean of any other signal coming from ballast to be sure ballast will feed correctly the voltage rate
Re: 12v power source key on and cranking? [Re: GTSDart340] #2340403
07/20/17 03:46 PM
07/20/17 03:46 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Discussed before, you need an ISO relay.
Re: 12v power source key on and cranking? [Re: GTSDart340] #2340586
07/20/17 10:18 PM
07/20/17 10:18 PM
New Mexico
UCUDANT Offline
Troll Hunter
UCUDANT  Offline
Troll Hunter
New Mexico
A thread started in 2015 on http://www.forabodiesonly.com about the FiTech systems is still going
http://www.forabodiesonly.com/mopar/threads/fitech-efi-system.321984/
Pay close attention to proper venting back to the tank
Re: 12v power source key on and cranking? [Re: GTSDart340] #2340652
07/20/17 11:16 PM
07/20/17 11:16 PM
BDW Offline
BDW  Offline
Just went through this, I actually don't think the diode is needed.
But that's what's in mine
https://board.moparts.org/ubbthreads/ubbt...nk-and-run.html
Re: 12v power source key on and cranking? [Re: GTSDart340] #2340877
07/21/17 11:37 AM
07/21/17 11:37 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
We have discused already that ( thread posted by cnxt )... diode is a must because if not, will result the same than ALLMOT bypass the ballast. The ballast will keep feeding the 86 terminal and that's imposible to save... and if the relay reacts on the ballast feed to coil, will stay on.. adding also more load to the coil circuit, changing the ballast output too... and the 30 terminal won't be getting either 12 volts, but the ballast output
While the relay doesn't react to the ballast voltage, will be nice, but if switches, you will be on a different world.
( not being a smartass, but being logic on how the circuit works )
Re: 12v power source key on and cranking? [Re: GTSDart340] #2341150
07/21/17 08:45 PM
07/21/17 08:45 PM
Laveen, Arizona
Laveen, Arizona
Thanks for all the help. I bit the bullet and bought an msd box and distributor. It was in the plan eventually anyway. Thanks again!
Re: 12v power source key on and cranking? [Re: GTSDart340] #2341155
07/21/17 08:57 PM
07/21/17 08:57 PM
New Mexico
UCUDANT Offline
Troll Hunter
UCUDANT  Offline
Troll Hunter
New Mexico
Now you can make a simple piggy back wire to jump the ballast wires together and tie in the power for the unit, leaving the factory wiring in place. .....
You're going to love the timing control, you'll need to disassemble and lock down the disributor.
Make sure your timing light is compatible with the MSD
Re: 12v power source key on and cranking? [Re: UCUDANT] #2341171
07/21/17 09:27 PM
07/21/17 09:27 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Or just get a single pickup lean burn distributor
All new LA lean burn distributor Spectre CH11
Don't be the exception.
Re: 12v power source key on and cranking? [Re: Supercuda] #2341186
07/21/17 10:09 PM
07/21/17 10:09 PM
New Mexico
UCUDANT Offline
Troll Hunter
UCUDANT  Offline
Troll Hunter
New Mexico
...he already bought an MSD
Re: 12v power source key on and cranking? [Re: Supercuda] #2341226
07/21/17 11:01 PM
07/21/17 11:01 PM
BDW Offline
BDW  Offline
What's the benefit of this?
Re: 12v power source key on and cranking? [Re: GTSDart340] #2341237
07/21/17 11:12 PM
07/21/17 11:12 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
It's already locked out, there are no moving parts inside the housing other than the shaft/rotor. No mechanical advance, no vacuum advance.
