If ballast is required, NEVER feeds anything from coil wire because will vary the voltage rate coming from ballast to feed the coil. The coil wire lead must remain clean of any other signal coming from ballast to be sure ballast will feed correctly the voltage rate
With a Charger born in Chrysler assembly plant in Valencia, Venezuela
