Radiator Catch Cans #2335615
07/11/17 11:36 PM
07/11/17 11:36 PM
Spokane Valley, WA
Big Bad Bee Offline OP
Spokane Valley, WA
After dumping $280 worth of Evans into my new radiator I started thinking I'd be smart to get a catch can to keep the liquid gold from hitting the pavement. What type catch can do you use and what capacity is right for a 3 row 26" core radiator on an RB engine?
I’m listening.
Re: Radiator Catch Cans [Re: Big Bad Bee] #2335629
07/11/17 11:58 PM
07/11/17 11:58 PM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
$280 worth??!! Dang, how big is your radiator? I use one of these. https://www.summitracing.com/parts/sum-g1472/overview/
Re: Radiator Catch Cans [Re: forphorty] #2335673
07/12/17 01:15 AM
07/12/17 01:15 AM
Spokane Valley, WA
Spokane Valley, WA
26" 3-Core aluminum Champion. Trust me. with an empty block, heater core, hoses and radiator and an RB block, it will take 6 gallons ish. At the local speed shop this stuff is $42 a gal.
I’m listening.
Re: Radiator Catch Cans [Re: Big Bad Bee] #2335746
07/12/17 09:24 AM
07/12/17 09:24 AM
Keymar, MD
DusterKid Offline
DusterKid  Offline
Keymar, MD
I use the one forphorty uses on my race cars, they do their job.
Re: Radiator Catch Cans [Re: DusterKid] #2335809
07/12/17 11:34 AM
07/12/17 11:34 AM
moparx Online content
moparx  Online Content
would considering using a factory style overflow jug that returns any overflow back to the system during cooldown be a possibility ? if so, you would need a late style, double gasket cap, and a tank or can that has the overflow tube positioned near the bottom of the can so when the liquid cools, it is drawn back into the radiator via suction.
beer
Re: Radiator Catch Cans [Re: Big Bad Bee] #2335867
07/12/17 12:53 PM
07/12/17 12:53 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
i asked this a few years back so this might help. i have of course done nothing with the info except save it realcrazy
https://board.moparts.org/ubbthreads/ubbthreads.php/ubb/showflat/Number/8263857/site_id/1#import
Re: Radiator Catch Cans [Re: Big Bad Bee] #2335880
07/12/17 01:19 PM
07/12/17 01:19 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
Take into account the expansion for 6 gal at 200*F and that would be the size of the tank.imo
Re: Radiator Catch Cans [Re: Clanton] #2336912
07/14/17 02:45 PM
07/14/17 02:45 PM
Spokane Valley, WA
Spokane Valley, WA
I have no idea what the expansion rate of Evans coolant is but the idea has merit.
I’m listening.
Re: Radiator Catch Cans [Re: Big Bad Bee] #2336943
07/14/17 03:52 PM
07/14/17 03:52 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
A recent technical enquiry to Evans resulted in the following replies:
Q1. What is the coefficient of thermal expansion over range -20degC to +120degC,
A1. The co-efficient of expansion of water based 50/50 standard automotive antifreeze is approximately 5% by volume, Evans Waterless Engine Coolant is approximately 6% by volume.
Q2. Is this expansion consistent across that temperature range?;
A2. Yes, this expansion rate is consistent across these temperature ranges and again similar to that of 50/50. The 6% by volume figure is based on the high end of the temperatures that you have stated above.
Re: Radiator Catch Cans [Re: Big Bad Bee] #2337030
07/14/17 07:19 PM
07/14/17 07:19 PM
BDW Offline
BDW  Offline
I just ordered the Hyundai 1, $15 shipped, I'll post how it works out.
I'll have to figure out a way to mount it.
Re: Radiator Catch Cans [Re: BDW] #2337042
07/14/17 07:51 PM
07/14/17 07:51 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
and i broke down and ordered the Dorman one that i can mount behind the fender. 20 from Napa. we'll see tomorrow or Sunday but at least i don't have to feel guilty about not following through on my asked question. biggrin
