Radiator Catch Cans
#2335615
07/11/17 11:36 PM
07/11/17 11:36 PM
Posts: 10,938 Spokane Valley, WA
Big Bad Bee
Spokane Valley, WA
After dumping $280 worth of Evans into my new radiator I started thinking I'd be smart to get a catch can to keep the liquid gold from hitting the pavement. What type catch can do you use and what capacity is right for a 3 row 26" core radiator on an RB engine?
I’m listening.
Re: Radiator Catch Cans
[Re: forphorty]
#2335673
07/12/17 01:15 AM
07/12/17 01:15 AM
Big Bad Bee
Spokane Valley, WA
26" 3-Core aluminum Champion. Trust me. with an empty block, heater core, hoses and radiator and an RB block, it will take 6 gallons ish. At the local speed shop this stuff is $42 a gal.
I’m listening.
[Re: Clanton]
#2336912
07/14/17 02:45 PM
07/14/17 02:45 PM
Big Bad Bee
Spokane Valley, WA
Take into account the expansion for 6 gal at 200*F and that would be the size of the tank.imo I have no idea what the expansion rate of Evans coolant is but the idea has merit.
I’m listening.
[Re: Big Bad Bee]
#2336943
07/14/17 03:52 PM
07/14/17 03:52 PM
Posts: 25,783 Rio Linda, CA
John_Kunkel
Rio Linda, CA
A recent technical enquiry to Evans resulted in the following replies:
Q1. What is the coefficient of thermal expansion over range -20degC to +120degC,
A1. The co-efficient of expansion of water based 50/50 standard automotive antifreeze is approximately 5% by volume, Evans Waterless Engine Coolant is approximately 6% by volume.
Q2. Is this expansion consistent across that temperature range?;
A2. Yes, this expansion rate is consistent across these temperature ranges and again similar to that of 50/50. The 6% by volume figure is based on the high end of the temperatures that you have stated above.
