AAR p/s pump. #2330597
07/03/17 11:52 AM
07/03/17 11:52 AM
MERRILLVILLE, INDIANA
sunroof446 Offline OP
I am restoring an AAR for a customer, my p/s pump pulley is not lining up, trying to figure out what is going on, I know the crank and water pump pulley is correct. the casting number on the p/s pump is 2537955 with a 3 spoke pulley. Any input would be appreciated.
Re: AAR p/s pump. [Re: sunroof446] #2330615
07/03/17 12:13 PM
07/03/17 12:13 PM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
Mine has a federal pump with a solid pulley, if that helps. Sounds like you have the wrong pump and/or pulley. You may have a BB pulley. The SB with the Saginaw pump has a different offset.
Re: AAR p/s pump. [Re: fastmark] #2330692
07/03/17 02:11 PM
07/03/17 02:11 PM
This one doesn't have a solid pulley, I have no clue where the customer got this pump from, definitely wrong. Just trying to figure out what I need. Thanks.
Re: AAR p/s pump. [Re: sunroof446] #2330698
07/03/17 02:24 PM
07/03/17 02:24 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Photos would help.
I do not recall seeing any original AARs or T/As with a solid pump pulley.
Re: AAR p/s pump. [Re: Alaskan_TA] #2330735
07/03/17 03:55 PM
07/03/17 03:55 PM
The pulley is 7 inches in diameter. casting number on pump is 2537955. Customer supplied his own parts. He started out with the wrong crank pulley, I have the right crank and w/p pulley on now. definitely something up with the pump, pulley, or
both.
19756475_1616461748378687_3106755978771766326_n.jpg19642677_1616461788378683_2545072587269387996_n.jpg
Re: AAR p/s pump. [Re: sunroof446] #2330743
07/03/17 04:13 PM
07/03/17 04:13 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
No Saginaw pump on a 1970 340. Aren't they federal pumps on them?
Re: AAR p/s pump. [Re: NANKET] #2331031
07/03/17 10:03 PM
07/03/17 10:03 PM
Banana Republic
FM3AAR Offline
FM3AAR  Offline
Banana Republic
Here's the original pump on my AAR.
“You’ll own nothing” — And “you’ll be happy about it.”
K. Schwab
Re: AAR p/s pump. [Re: FM3AAR] #2331078
07/03/17 11:27 PM
07/03/17 11:27 PM
would you happen to have the casting number that's on the bottom of the pump? and possibly a photo looking straight down from the top. I would like to see the distance of the pulley to the pump body. Thanks.
Re: AAR p/s pump. [Re: sunroof446] #2331187
07/04/17 06:29 AM
07/04/17 06:29 AM
Banana Republic
FM3AAR Offline
FM3AAR  Offline
Banana Republic
Hope these work for you.
K. Schwab
Re: AAR p/s pump. [Re: sunroof446] #2331192
07/04/17 08:12 AM
07/04/17 08:12 AM
Thanks, I have the same casting number, I must have the wrong pulley on the pump or crank, My water pump lines up fine so I think I can eliminate the crank pulley, looks like your p/s pulley sits closer in.
Re: AAR p/s pump. [Re: sunroof446] #2331530
07/04/17 07:21 PM
07/04/17 07:21 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
I dug out the two I had. One is from a car without AC & the other had AC.
The pulleys are different on mine.
The non AC version has curved spokes.
The AC version has flatter spokes.
Rough guess without measuring is close to a 1/2 offset difference between the two.
If needed I can put them in the parts washer for a cleanup & get photos.
Re: AAR p/s pump. [Re: Alaskan_TA] #2331612
07/04/17 10:34 PM
07/04/17 10:34 PM
The pulley on mine is sitting about a half inch to far forward, looks like I have an a/c pulley on the pump from your info. Thanks for checking.
Re: AAR p/s pump. [Re: sunroof446] #2331732
07/05/17 01:44 AM
07/05/17 01:44 AM
Banana Republic
FM3AAR Offline
FM3AAR  Offline
Banana Republic
Here's a pic of my AAR pulley after bead blasting. I was unable to make out the numbers where I have the X's.
K. Schwab
Re: AAR p/s pump. [Re: sunroof446] #2331757
07/05/17 04:49 AM
07/05/17 04:49 AM
WA
tman Offline
tman  Offline
WA
Hmm, maybe reverse the pulley? Disregard.
Re: AAR p/s pump. [Re: tman] #2331758
07/05/17 05:01 AM
07/05/17 05:01 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
it appears the Federal small block pump used the same pulley 1970-'73 #2951 901
per the Parts Catalog(s): 19-54-86 PULLEY, Pump B/J
1970 (May 1970)
2951 901 - 318 & 340 w/3/8" threaded hole pump shaft (A & B-bodies also)
2951 989 - 318 & 340 w/key slotted pump shaft (B-bodies also)
1970-'71 (January 1972)
2951 901 - 318 & 340, 340 3-2bbl w/3/8" threaded hole pump shaft (A & B-bodies also)
1973 (September 1972)
2951 989 - 318 & 340 w/key slotted pump shaft (listed as E-body ONLY)
neither of these pulleys are shown in the '69 Parts Catalog
neither are shown as used on a C-body
the 2951 989 is also listed in the '72-'73 Truck Catalog for B/W/D & 225/318/360
Re: AAR p/s pump. [Re: 6bblgt] #2331762
07/05/17 05:28 AM
07/05/17 05:28 AM
Sweden
71redcuda Offline
71redcuda  Offline
Sweden
Dont forget the inspection markings..
Re: AAR p/s pump. [Re: 6bblgt] #2331764
07/05/17 05:33 AM
07/05/17 05:33 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
HOLLANDER shows: work
AAR & T/A FEDERAL pump w/reservoir (NO pulley) #3004 799 the same as 1969-'72 C-body
VS.
E-bodies FEDERAL pump w/reservoir (NO pulley) #3004 800 the same as 1969-'72 B-body and others
& I lightened FM3AAR's pic
Re: AAR p/s pump. [Re: 6bblgt] #2332289
07/06/17 01:25 AM
07/06/17 01:25 AM
North Dakota
Azzkikrcuda Offline
Azzkikrcuda  Offline
North Dakota
If you run out of ideas you can put the pulley in a press and rebend it to the depth you need to line up. I have done this to quite a few over the years. Then install it on the pump, clamp the pump in a vise and spin it to check pulley run out. If you need to adjust it you can just bend it by hand. The 3 spoke pulleys are very easy to bend.
The only Carbs I care about are under the hood!
Re: AAR p/s pump. [Re: Azzkikrcuda] #2332347
07/06/17 08:57 AM
07/06/17 08:57 AM
Looks like I have the wrong pulley on the pump, Thanks everyone for the help, I appreciate it.
Re: AAR p/s pump. [Re: sunroof446] #2335516
07/11/17 09:20 PM
07/11/17 09:20 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
I cleaned mine up for photos. These pulleys are the same diameter, both pumps are 955s but notice the pulley to pump offsets.
The one at left is from a 340 with 3.91 gears, so it has the cooler.
